Old 11-29-2003, 11:17 AM
webpilot webpilot is offline
Question Pinion Removal ?
Does anyone know how to remove the pinion gear without a pinion gear puller?
Old 11-29-2003, 12:25 PM
GhettoFiedRacin's Avatar
GhettoFiedRacin GhettoFiedRacin is offline
you are not your xmods
Send a message via AIM to GhettoFiedRacin
ive been tryin different methods... such as prying, yanking , and of course pulling .... none of thse have worked tho
I like the way you drive. Hittin walls and bouncin on the sides. Cuz the glare off my rims hit ur eyes
Old 11-29-2003, 12:33 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
i had my sis's boyfreind help me pull it off. it does NOT want to come off!! i finally got it though! i decided i did not want the moter any more so i put it in a vice(really tight(it even brock the magnets!)) and i pried like crazy!! the shaft came out of the motor so we bent the shaft, put it back in the vice and took two screw drivers on both sides and then it finally came off(took about 15 min.)
--Chris
Aka...aero528
Old 11-29-2003, 01:52 PM
miniDRIFTER's Avatar
miniDRIFTER miniDRIFTER is offline
modSquad Member.
Send a message via AIM to miniDRIFTER
OMG, thats crazy, looks like someone really wanted that pinion gear.. lol.
White '97 Toyota Supra
Mild front, wild sides, stock back
Stage II motors
Hard suspension
Black painted Enkei wheels
Command Logic lights (Courtesy of http://www.xmodrc.com)
In the process: XMOD™ Dynamometer (DYNO)
Old 11-29-2003, 10:07 PM
aero528's Avatar
like my dog??
i wanted it to use on my tamiya motor.(will tell you how it runs after i get my new diff(ored it on friday))
--Chris
Aka...aero528
Old 11-30-2003, 01:46 AM
Mr BigShot Mr BigShot is offline
TinyRC PRO Modder
OMG you said it
Man i just went out to my local hobbie shop today , and bought i real nice pinion puller for 8.99 + tax Then i came home and ripped all my kids crapy cheap Rc car's apart that were in the Rummage sale box , and found al kinds of motors to play with
Old 11-30-2003, 02:00 AM
neurokinetik's Avatar
I haven't found any method that works well without using a pinion puller. The problem with not using one is that usually the motor ends up destroyed, and the teeth of the pinion usually get damaged as well. One way you can gain some pinion clearance for the puller is to use a pair of large diagnal pliers, and put the gear into them like you are going to cut the motor shaft off just below it. Squeeze the pliers, and you will move the pinion about 1/16th of an inch. Enough to get the puller in, and not kill the motor.
Old 12-02-2003, 11:38 AM
mbartell mbartell is offline
so I re-wired it
Quick science lesson here- the pinion is brass, the shaft is steel. Brass expands faster with heat. Use your soldering iron or a micro torch to evenly heat up the brass pinion and you can pry it off. Be careful when you do it, because it may fly across the room when it lets go, and it will still be hot.
To put the pinion back on, use a c-clamp. Heat will also help.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 12-02-2003, 03:23 PM
MicroSpeed's Avatar
/\ what he did works well, and it doesn't destroy your motor as much.
I think the pinion is glued on, but when you heat it up it slips right off, with the help of some pliers.
Old 12-02-2003, 04:07 PM
I tried heating it up with a grille lighter, and it didn't help at all... :shrug:
Old 12-02-2003, 07:04 PM
modSquad Member.
Guys, if you didnt know, they sell pinion pullers, they are like 10 bux, save yourself the work and just buy one. Imma laugh when one of you burn the crap outta ur motor trying to do this. ..
Stage II motors
Hard suspension
Old 12-02-2003, 11:14 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
In San Antonio, finding anything related to slot cars seems to be very difficult...
I like that heat method. Tried it myself, but stopped due to the danger . I never thought of heating it with a soldering iron though...
Old 12-04-2003, 07:04 PM
ninja828 ninja828 is offline
just to tell you guys, the heating method won't work with an RS 25 watt soldering gun.......look like ima hafta torch tha lil sucka
Old 12-04-2003, 08:48 PM
fr33flow fr33flow is offline
Send a message via AIM to fr33flow
lol this is funny
i really wanted to get the pinion off so i put the xmod motor in my vice and i took a hammer and screw driverand i hit the screwdriver and i knocked the pinion along witth the bar its attached to. i got the SB motor apart and everything but now i gotta get the darn pinion off to use it! any ideas?i thought maybe i could cut the very top of the silver rod and then drill it out of the pinion.
Lol i got bored and put the silver rod in my vice and beat the pinion off with a screwdriver and hammer.
}{-[V]()l)- 03' RSX- stage 2 motor, body kit, lights, and soon to have SB motor.
Soon to get: suspension, tires, and rims(just gotta have rims_BLing BLing!
HowTo-SB magnet mod: No pinion removal !!! Exaran XMODS Science 40 07-16-2004 01:29 AM
Pinion Removal SupraFreak00 XMODS Parts and Hop-Ups 1 06-09-2004 02:18 PM
found possible pinion Jamezracer XMODS 3 02-02-2004 07:06 PM
Looking for 7 spoke pinion gear for bit motors syncronized For Sale/Trade 0 04-21-2003 04:10 AM
