12-02-2003, 07:20 PM
Master Debater
Which zz to buy?
After coming back to tiny rc's for the zzse and being disapointed I want to get a regular zz. I have had a lot of other cars before but I want a clean slate with this car.
Which zz would be best? Do any others besides the jeep have springs? Do they all have the good pcb in them? Which body is the lightest? Do the zzse springs fit the regular zz?
Thanks in advance.
12-02-2003, 09:00 PM
That's all folks
So far, the jeep is the only one I have seen with the spring suspension. I am not sure if the SE spring are the same, but they sure look like it. I think they all have the latest revision of the pcb. I was dissappointed with the SE's at first, untill I had a mosfet mod done. Now I would trade any Zip Zap or bit/ms for a fet modded SE, that is about all I drive anymore! I think the eclipse bodies (green from fnf tuner and purple convertible from 2f2f tuner) are the lightest.
That's all folks!
12-02-2003, 09:55 PM
So far the Shale Green Jeep is the only non-SE with springs, the yellow one doesn't have them. As far as the difference between the SE and Jeep springs, although they are the same size (and would be interchangable), the SE springs are considerably stiffer, I guess to compensate for the additional weight of those "rolling bricks", as I like to call 'em -
12-02-2003, 09:58 PM
Master Debater
Has anyone used the se springs on the reg zz? I think the zzse springs are to soft anyway, so with less weight it would be better. Also, I think I want the 350z body. Does this one have the latest pcb? How does it compare, in weight, to the other bodies?
12-02-2003, 10:10 PM
That's all folks
Yeah, the 350Z has the latest pcb, it is also a pretty light body.
That's all folks!
12-03-2003, 08:24 AM
Master Debater
Ok, im gonna get that. Does the 27mhz version have range problems?
12-03-2003, 03:39 PM
I'd get 49mhz. 27mhz has the most problems with me.
12-03-2003, 06:12 PM
Master Debater
That's what I thought but my bro has a 49mhz ms and plus I like the red body. I think I'll just get the 27mhz. My se didn't have range probs (but it did have every other kinda problems you can have).
12-03-2003, 09:23 PM
Master Debater
Also, is it possible to get a zip with equal steering? That is my main problem with all my tiny rc's. They turn one way sharper than the other.
