Old 11-23-2003, 02:42 AM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
any pics or updates on the rest of the mounting? i'm really interested in seeing how the clip was done for the mini cooper
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-25-2003, 04:03 PM
Ace25 Ace25 is offline
I ve been thinking about buying one of those bodies, and I was wondering... will all Mini-Z bodies fit on X-MODS? and if so, when installed by your directions, do the bodies fir, or do they just lay on the bodie so when you pick it up the car stays on the ground but the body comes up? Thanks for all your info.
Old 11-27-2003, 12:21 AM
neurokinetik's Avatar
Ask, and you shall receive. Though not necessarily in a timely manner, as I work on too many different projects simultaneously. :lol: Front tab is not satisfactory yet, and I need to come up with how to attach either the sides or the back.
Not all bodies will fit. Many will, as the wheelbases are similar, if not identical. The real stumbling block is low hood clearance like I ran into on the C5R. The MINI body has two challenges, the first of which is the tight wheelwells, the second of which is the narrow width. I can't even put the battery clips on with this body. Most Mini-Z bodies should fit easily by making a new front tab, and using velcro on the battery clips. The body is quite secure when mounted this way.
Old 11-27-2003, 05:59 PM
Char-g Ace's Avatar
Char-g Ace Char-g Ace is offline
I need to change my Title
I fyou could do one like a MINI Cooper S I would buy it give it to my dad for xmas.
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Celica body
Old 11-27-2003, 08:40 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
im thinking ill have to buy the mini-z Calsonic Skyline GT-R just so i can have a real race looking body........that or the CLK........(i hope i dont make my R-34 jealous.....lol....)......
-Andres
Old 11-30-2003, 01:05 AM
http://mini-zracer.com/shop/product.php?pid=462
That one takes you right to it...
Old 11-30-2003, 03:23 PM
Here's the revised front mount. I was unhappy with the old one. This one is both stronger, and also doesn't interfere with front suspension movement like the old one did. This one is made of pieces from the Mini-Z Autoscale chassis battery cover, a couple of wheel nuts, and alot of slow-setting CA glue used with accelerator.
Still trying to get the rear mount sorted. I may cut a slot into the rear of the MINI Body for the little tab I created (shown in this thread: http://www.tinyrc.com/forums/showthr...threadid=14230 )to seat into. Right now, the rear mount is pulling the entire body backward, causing wheel rub issues, due to the extremely tight fenders on the MINI. This body is proving to be more of a challenge than I initially thought, due to the extremely short (almost nonexistent) front and rear overhangs, and the narrow width (can't use the battery clips with this body).
Old 11-30-2003, 06:26 PM
Another one finished. This has been a productive weekend. I had to do alot of sanding in the wheelwells to solve tire rubbing issues. ALOT of sanding. I also had to reduce the offset of one set of wheels to hwlp a bit more. Which meant even more sanding...
Here's the rear mount, as shown in the Corvette ZR1 project.
Ready to run...
Note how tightly this body fits to the chassis...
Old 11-30-2003, 10:26 PM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
looking very good
keep up the good work
All Wheel Drive=Fun!!!
Old 11-30-2003, 10:54 PM
Got 4.2 King? I do : )
that looks damn nice, i bet your troubles were worth it
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 12-02-2003, 11:09 AM
Skurge420's Avatar
Skurge420 Skurge420 is offline
Gerbil Racing
Send a message via AIM to Skurge420
the mini body is the best!
awesome fit
whenever i get round to picking up a xmod i will get that body
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
Old 12-02-2003, 06:59 PM
anthonyb45
nice nice but can u turn that good? it looks like the wheels r going to hit the body
Anthony
Old 12-02-2003, 08:46 PM
LP_Reanimator LP_Reanimator is offline
That's not very proportional to the real thing. It's supposed to be smaller than the other cars, but it still looks pretty good. You should paint it.
Old 12-02-2003, 09:21 PM
Alex's Avatar
Alex Alex is offline
sex: Yes please!
Send a message via AIM to Alex
good luck when you hit a bump that your batteries dont move out of place..
Old 12-02-2003, 11:05 PM
Anthony
With all of the sanding I did on the wheelwells, yes I can turn full lock with no rubbing. Look at the pic at the top of the page and compare it to the one at the bottom, especially at the front of the car.
Actually, you'd be surprised. It's quite a bit smaller than the RSX in all dimensions but the roof height. The new MINI isn't really all that small, especially compared to the original. As for paint, it is staying black, but I might do the roof in white, along with adding the white stripes on the hood, like the cars in The Italian Job. That's the extent of it, though, as this body is intended to be a race body.
mini cooper body sawhit4 Mini-X 20 01-03-2004 12:47 AM
Mini cooper from kmart vtheo Bit Char-G / MicroSizers 8 07-31-2003 04:24 PM
Project Car: Mini Cooper! johnrtse Bit Char-G / MicroSizers 7 12-19-2002 09:11 PM
