Actually the ball rear diff is more like a posi. (and a little like a slipper clutch if it's loose)
If you want to make a locker- like a solid axle, use silly putty.
Open up your gear diff.
put a small ball of silly putty on each gear
squeeze it closed, and your differential will be locked solid.
This will help more for drag and straight line. It will make the car skid around more, and I guess you could call that drifting, if you want to.
The best part is that you can take it apart and remove the silly putty, unlike glue or epoxy.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
