11-30-2003, 07:40 PM
I know that stage one and two motors are different. my question was whether each of the stage ones were the same except gearing. and the stages two motors were the same except for the gearing, not whether all the motors are the same, i know the stage ones have a different wind than the stage twos.
tomorrow i try out my cybersonic motor, the magnets are diiferent the the sbp and sb ones and it has a nicer looking wind, i think it may not have as much torq but I am hoping for some good top end.
11-30-2003, 07:49 PM
Xmod Modifier
YEAH THE STAGE ONES ARE EXCATLY THE SAME AS EACH OTHER CEPT GEARING
XMOD 1997 Red Toyota Supra //LED kit//Skyline Rims//
Blown White Stock Stage 1 motor (RIP)
Modified SBP High Torque Drift Motor
8 tooth pinion (lightened)
Nasty sleeper paint job
5th cell N-cell (rare) mod!!!
Pioneer in SBP 5th n-cell Technology.
4 IC3's 800mah Batteries & 1 n-cell (RS)
Silver RSX (Scraped Skyline and RSX)
Made from returned broken cars.
RSX and Supra Rims
All stock skyline chasis shortened to fit RSX.
Uses an RSX shaft and Broken limited slip gear.
White 6 cell Supra SBP II Hybred With unknown magnets... Bearings and oil cooled. Too fast! Eats tires
11-30-2003, 08:17 PM
you are not your xmods
ive done it... with extremely good results .... GO BUY A SPINBRUSH
I like the way you drive. Hittin walls and bouncin on the sides. Cuz the glare off my rims hit ur eyes
12-01-2003, 12:20 AM
Originally posted by hotrod29728
someone please help me out with the slot car motors !!!!!!!!!!!
You may need a turbo to run some slot car motors.
12-01-2003, 10:52 AM
what kind of turbo?
like a fifth or sixth cell?
or something diffrent?
i am new with these little things...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
12-01-2003, 11:23 AM
Originally posted by jaubery
I tried the ff-180 or spin brush motor. The mod requires you to shim the rear motor mounts. You can't use the front mount at all. The motor also requires capacitors to be soldered onto it.
As far as performance goes I had dissapointing results. It has good acceleration, but the motor has no top end. A stage 2 drag is faster.
jaubery
Wait a minute, is the motor in the "Pro" version different than the "Multiangle" or "standard" versions of the Spin Brush? Because I did not use a "Pro", and the motors are a standard FA-130 sized, exactly the same size as the XMod motors.
12-01-2003, 11:29 AM
Xmod Modifier
They are the same, The person you quote didnot buy a spinbrush motor as they are a perfect fit.
RSX and Supra Rims
12-01-2003, 06:47 PM
is anyone looking to sell one with a blue pinion installed and the other things soldered on also.
email me at fr33flow@msn.com or AIM at p8ntballer1788
}{-[V]()l)- 03' RSX- stage 2 motor, body kit, lights, and soon to have SB motor.
Soon to get: suspension, tires, and rims(just gotta have rims_BLing BLing!
12-02-2003, 02:17 AM
i have a pro and reg spin brush motor and they appear to be exactly the same, wind, magnet size everything. I am going to test all my motors tomorrow to see which one has the best times, acceleration and such. I am testing a stage one drift, a stage two drift, drag, race, and top speed, along with a spin brush motor with 11 tooth pinion, and a mabuchi motor out of a cyber sonic tooth brush also with 11 pinion. orgingallly i thought the mabuchi might be the fastest, but after just hooking the motor up with out a gear, I am leaning more towards the sbp motor. I'll make a post with times and distances tested tomorrow.
12-02-2003, 03:21 PM
ABSOLUTELY AMAZING
haha so much talk about these SBP motors I cant wait to install it(its easy right???) but one question do they drain out batts really quickly....and one more thing I saw the IC-3 RADIO SHACK batts not rayovaks selling for 39.99 at rs they are the same right in power output?? and also I saw the duracell rechargeable batts (dont think they rechange in 15min) but information said: Duracell Accu Rechargeable 1800mAh AA NiMH Batteries for 19.99 and they cheaper so I was wondering if I went with these and the the rayovaks or the rs's IC-3 batt it would be the same???
Yellow-1999 Nismo Nissan Skyline R34
Stock
12-02-2003, 03:22 PM
* and not the
Stock
12-02-2003, 09:19 PM
the rechargeable RS battery kit is a must...
Project Supra:
97 Supra
Black, Red hood
Mountain Dew skid plate
Custom Spinbrush Motor (11T/blue gear)
Custom 5th Cell System (9V)
Stock tires, superglued (didnt help)
Light kit
Wild body kit
more soon
12-02-2003, 10:50 PM
Xmod Modifier
I have IC3's by Rayovac which is only 19.99 at walmart. 1/2 the price of Radioshack even after my discount. So yeah I love them allot. Good run times too, I need to find a rechargable N-cell now
RSX and Supra Rims
12-03-2003, 09:56 AM
i may be 13 but ive been dealing with slotcar motors for like 5 years... the size of the magent doesnt matter the pull of the magentic field is...
i hae a group 12 motor right here that the mags are so strong when you turn the armature you can feel the maggs pulling at the motors its got kinda like a brake on it from the magnets too because the magnetic pull is so strong when you let go of the throttle
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
12-03-2003, 06:51 PM
while thats true, having thicker magnets helps to close the gap between the mag and the armature, creating more torque.
New to small cars...well I used to have a DRR.
go to
