Old 11-30-2003, 05:50 PM
Chrisman222's Avatar
Chrisman222 Chrisman222 is offline
The One Punisher
Send a message via AIM to Chrisman222
weight
my xmod is seems 2 heavy...wat suggestions do u ppl have 4 cutting out some of the wieght. i need 2 lighten the load but im not sure wat mods i can do 2 it? Also, should i take of body parts like spoilers etc.
post ur ideas about how 2 make ur xmod lighter. thxs
Old 11-30-2003, 05:53 PM
viperkilla's Avatar
Yea use the stock body kit. The mild and wild body kits weight it down. You could uninstall AWD if you have it since it adds more weight to the car.
Old 12-01-2003, 01:35 AM
Snow Snow is offline
DDR PIMP
Try taking out those beige-colored plates and replacing them with thinner, lighter plastic.
Thunder Charger
Old 12-01-2003, 08:19 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
if you have AWD installed use the top plates that held the front end together instead of the plastic top plate that comes with the car.
NEVER UNDERESTIMATE THE POWER
Old 12-01-2003, 12:30 PM
major skyline's Avatar
major skyline major skyline is offline
Sleeper Supra
i took a dremmel and ground the corners off all the "sharp" bends+ angles
Old 12-01-2003, 01:53 PM
colin4371 colin4371 is offline
PPG Co-Owner
take a dremel and shave everything in the inside of the body, and drill lots of holes in lots of the stuff on the chassis e.g. battery clips, underparts of the chassis, etc.
Old 12-01-2003, 09:07 PM
Martlet21 Martlet21 is offline
Send a message via AIM to Martlet21
Just take off the body, that'll make it hella light.
Old 12-01-2003, 09:16 PM
security civic security civic is offline
sleeper mall civic
Send a message via AIM to security civic
i took off the thing where u screw the antena in and i sanded down the body and its kinda light now that the body is thiner im gona replace the other tan thing in front with a peice of plastic
douglascounty!!!
Old 12-01-2003, 09:22 PM
Lucid Dreams
you can take the front over off that would cover the awd gears
take the battery clips off and whatever else you can find to replace i guess
Body Weight Steve ZipZaps Mods and Projects 3 02-19-2006 08:56 AM
Weight Jtskty Bit Char-G Mods and Projects 10 12-14-2003 02:34 AM
Initial D is addictive zombiebaby Bit Char-G / MicroSizers 96 07-20-2003 01:31 AM
Weight distribution maxximum attack Bit Char-G Mods and Projects 6 07-19-2003 08:18 PM
Antenna Weight mod DisfourDan Wild Char-G 6 01-14-2003 09:02 AM
