11-28-2003, 05:01 PM
("\(0.o)/") Rawr!
AWD help
I jst bought the AWD upgrade,before I install it I wanna knoe all the trick to it, like something to do with leaving the stock diff when u upgrade it? please give me tweaking tips on how to have this baby fly!
Xmod Parts Help
11-28-2003, 06:30 PM
Put it on like you would regularly but put in the stock differential in the back (that is the white one) dont put in the red one. Do the front like it tells you to. I have heard of some people puting the red diferential in the front and they said it makes your car go faster but i havent tried this yet. If you put the red one in the back it wont steer right. Dont ask me why it just dosent.
11-28-2003, 07:53 PM
("\(0.o)/") Rawr!
I got a problem, only three wheels move the front right barely move....plz help I left the stock def in the rear
Xmod Parts Help
11-28-2003, 08:38 PM
Hmm...make sure that everything is installed correctly. The gears in the front may not be meshing properly.
11-28-2003, 09:25 PM
("\(0.o)/") Rawr!
another Problem
i fixed that problem already they all turn, now another problem it turns to much to left then the right, I left the stock dif in the rear like i've been reading on some other threads, I jst don't knoe wat to do
*P.s. I also centered the steering servo long time ago so that can't be it.
Xmod Parts Help
11-29-2003, 02:40 PM
("\(0.o)/") Rawr!
can it be the tierod?
Xmod Parts Help
11-29-2003, 03:22 PM
I guess your best bet is to reassemble the AWD and then assemble it again.
11-29-2003, 04:20 PM
xmod destroyer
reply
try adjusting the strange on your controller
350z-SS 130 motor, bearings cf driveshaft, custom paint,
supra- high torque 180, 6 cell bearings,
civic- powerdash, bearings,cf driveshaft
rsx-fried
4supras fried
2 skylines detroyed
1 civic destroyee
11-29-2003, 08:01 PM
("\(0.o)/") Rawr!
Re: reply
strange?? or st. range? i did already still same probs
should i re assemble it? all part look correct. I think its the tierod, cuz i got the 4.5, and both front wheels are aligned like dat Example: > , not that togther though but u knoe wat i mean
still turns more left then the right
Xmod Parts Help
