Old 11-19-2003, 01:31 AM
FeRReT_of_WaR FeRReT_of_WaR is offline
rear wings, whats the point?
ok i have two questions. first do xmods go fast enough to make the wings put downforce on the cars? and secondly i hear you have you drill holes in your trunk to put them on. in which if they do then i would not want to put on a wing because i could not revert back to no wing.
Old 11-19-2003, 01:45 AM
SR20DETT SR20DETT is offline
The wings are srtrictly asthetic. My Skyline came with holes in the trunk for the wing. I don't know about the others though. PEACE
If your going to grab the shark by the tail, you'd better have a plan for dealing with the teeth.
Old 11-19-2003, 06:12 AM
MicroSpeed's Avatar
Skylines and both Supras already come with holes drilled, because they have wings on them stock. The RSX and both Civics do not have holes drilled in them, as they do not have wings stock. Drilling the holes for the wings is easy (I have an RSX), all you have to do is find the little indentations underneath the roof, use the drill bit size they tell you and drill away! To you first question-looks only
Old 11-19-2003, 09:36 AM
neurokinetik's Avatar
Believe it or not, the wings might actually make a difference. I know that my 1/12th scale car handled noticably different with different bodies and wing configurations, and after installing the short wing on my RSX, it seems to understeer at high speeds, which it never did without the wing. That was with an unchanged suspension setup.
Old 11-19-2003, 11:34 AM
XSupraStar XSupraStar is offline
I have the white Supra, and if you wanna use the "aluminum" wing that comes with the body kit you will have to drilll for those, other than that the stocky and other eing in the kit fit perfectly in the stock location. And also i think the wings do have a difference when i was driving mine around yesterday with the aluminum wing it wouldnt whip around like it did with the drag style wing that ive had on there. So i think it does make a difference, but hats just me, either way the wings look cool if done right. even the aluminum one.
-B
Old 11-19-2003, 02:42 PM
viperkilla's Avatar
Re: rear wings, whats the point?
I dont think that the spoilers dont do much. Also for civics you need to drill holes in order to place the spoilers on.
Old 11-21-2003, 03:58 PM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
your car should go faster without the wings because it is less weight
Old 11-24-2003, 09:38 PM
halo666 halo666 is offline
im stickin w/ the above post. I'm sure the wings aren't made to create downforce. that would be stupid. Its all about looks.
Old 11-25-2003, 11:33 PM
Daazndood Daazndood is offline
wing makes it easier to drift. although it may not be alot, it will be .000000000000000034% easier to drift WITH a wing. if you dont have a wing, you can say goodbye to that .000000000000000034% .
Old 11-26-2003, 12:54 AM
That's funny, but how would a wing make easier to drift? extra weight=better traction=drifters enemy.
Old 11-26-2003, 01:13 AM
well, the weight is in the back, making the back swing out easier? its like moving the battery cargo to the rear.
Old 11-26-2003, 09:44 AM
Ace25 Ace25 is offline
actually, the wings will make a diff. You have to think scale, our cars are 1:24, so for every 1 mph that we see them moving, to them they are moving at 24 mph and air is rushing over them at that speed so the wings provide downforce at such scales. Its all simple logic.
Old 11-26-2003, 09:49 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
hmmmmmmm.......so does that mean the wings on my bits and zzs work too????? lol......
-Andres
Old 11-28-2003, 02:00 PM
NiXaD's Avatar
NiXaD NiXaD is offline
Send a message via AIM to NiXaD
May the down force be with you
Setup:
97 Supra White
Soon To Come:
6th Cell (just have to wire it up)
Green Underglow (just have to wire it up)
Old 11-28-2003, 04:40 PM
I stand corrected. I did about an hour worth of research on the net and came up with many articles related to this topic. It's almost mind boggling when you start to really think about it. Good luck with all the math. PEACE
Rear suspension upgrade idea... neurokinetik XMODS Mods and Projects 2 12-29-2003 03:24 PM
Tuning Basics sperry XMODS Parts and Hop-Ups 12 11-19-2003 01:56 AM
Rear suspension on a bit? chelboed Bit Char-G Mods and Projects 28 04-13-2003 10:51 AM
Solved KIT rear issue...... DarkTari Bit Char-G / MicroSizers 0 02-10-2003 11:48 AM
whoa, Taiyo rear is removable, meaning: CUSTOM T BAR REAR SUPSENSION MOD TIME!!! MTL Auldey (All) 6 12-30-2002 08:53 PM
