Closed Thread
Old 11-28-2003, 01:19 AM
RedRSX's Avatar
RedRSX RedRSX is offline
Subaru WRX STi
Question Whats so good about locking your differentials??
Hey i read a thread about locking your differentials...now i know that 4-wheeling SUV's want that but why do you want that on your car??? Thanks
Old 11-28-2003, 08:52 AM
MattH's Avatar
MattH MattH is offline
2Fast4U
Send a message via AIM to MattH
Locking a differential will change handling. A locked rear diff will allow the car to turn really sharp. A locked front diff will allow the car to pull hard (accelerate) in the turns and carry a lot of speed in the bigger sweeping turns. I would personally just leave these parts alone, but if you run on a track with a lot of tight turns, try locking the rear. If you run on a track with large sweeping turns you might try locking the front diff. If you only drag race, try locking both.
Old 11-28-2003, 09:06 AM
Hairball Hairball is offline
Cheese Ninja
Send a message via AIM to Hairball
I locked my rear stock differential, and you can easily tell the difference. It has more even acceleration and, uh, stuff.
ThisonetimeIwaslostinthewoodsandIsawthisguywhohada steakandIwaslikewhoa.
  #4
Old 11-28-2003, 12:36 PM
racemini89's Avatar
racemini89 racemini89 is offline
SUPERBEAST
ummm how do lock a differential, and does it take speed away.
hello
  #5
Old 11-28-2003, 12:41 PM
RedRSX's Avatar
Subaru WRX STi
What would happen if i locked both differentials...would i handle better and accelrate batter??
  #6
Old 11-28-2003, 01:42 PM
aperson's Avatar
aperson aperson is offline
if you lock just one differential in an AWD car with 2 gear differentials it will lock both differentials because there is no 3rd diff in the middle of the two. to lock them you could put superglue in them or put a very thick oil or something in.
  #7
Old 11-28-2003, 01:51 PM
racemini89's Avatar
SUPERBEAST
instead of superglue would a hot glue gun work.
hello
  #8
Old 11-28-2003, 02:41 PM
oOfrog_BoyOo oOfrog_BoyOo is offline
Poopie monster
Send a message via AIM to oOfrog_BoyOo
I used silly putty
wat
  #9
Old 11-28-2003, 04:03 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
where exactly are the front and rear differentials?
  #10
Old 11-28-2003, 04:15 PM
R33E8 R33E8 is offline
The diff is the red circle that connects the motor to the axle. It has gears on it and is on the axel. There is one on the back and front. Um. If it is stock then it would only have it on the back and it would be white. Thats all i can explain about it now.
Xmods Civic:
  #11
Old 11-28-2003, 04:40 PM
Heat's Avatar
so do i just put the grease or whatever i use in the hole on both sides?
  #12
Old 11-28-2003, 05:59 PM
racemini89's Avatar
SUPERBEAST
ok i hot glued it and its accel sucks, it barly moves, and the reverse doesent work. i can pull the glue out but can someone post pics on how to do it.
hello
  #13
Old 11-29-2003, 01:54 PM
aperson's Avatar
heat, its easier to take it apart and superglue the gears together. i wouldn't reccomend doing this if you dont have AWD so you will have an extra differential if you screw one up. and you cant lock the Ball Differential/ Limited Slip Differential
  #14
Old 11-29-2003, 02:06 PM
eman1 eman1 is offline
custom title
dont use superglue. You can use some thick grease to semi lock the diff. Or you can use something like silly putty that is removeable.
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
  #15
Old 11-29-2003, 04:15 PM
Heat's Avatar
anyone wanna get me a screenshot :P i have 2 differentials so that's not my concern. i just dunno where to put the grease and what not.
Closed Thread
locking differentials lemans23 XMODS Parts and Hop-Ups 12 01-19-2004 01:40 AM
locking differentials turbopimp187 XMODS Parts and Hop-Ups 11 12-15-2003 07:36 PM
is plywood a good track surface? if not, what is? and barriers,. whats good??? eman1 Tracks 6 07-21-2003 03:48 PM
