Go Back   TinyRC.com > 1/24 and Smaller > Kawada Tripmate > Kawada Tripmate M-24
Old 10-07-2002, 08:14 PM
ScottM ScottM is offline
Question Newbie that needs some tips...
Getting a Mid-24 RX-7 kit...
I don't really know what i'm getting myself into, but it should be fun. I don't have any electronics for it yet... I haven't made a choice of motor or anything yet either.
Any tips that people have for me will be happily received.
-Scott
MicroSizers:
Red Lancer (27)
Yellow bB Open Deck (49)
Blue Skyline (27) :: Clone Motor (2.?)
Yellow RX-7 (49)
Black Celica (27)
White Impreza (49)
Old 10-09-2002, 12:55 AM
was ist los?'s Avatar
was ist los? was ist los? is offline
SpeedFreak
i don't own one, but i was going to buy one a few weeks ago. because there is very limited room for electronics, you should keep everything to a minimum. i recommend the airtronics es-01 electronic speed control$30, small receiver such as novak xxl or hitec shredder. you will need a radio$30-50. most come with receivers, but the entry level ones are way too big. i recommend getting a radio only magnum sport from futaba $40. then you would need a small servo. im not very familiar with what one should use, but probably a hitec unit which is $20-30. you will also need "dry" or rechargeable AAAs. i recommend AAAs from gp. these can all be purchased from tinyrc.com. just email tiny. you could always go to www.towerhobbies.com or www.microrcracing.com as well. hope i was of some help.
Old 10-09-2002, 06:21 PM
I own a mini-z already...
I'm trying to buy an ES-01 and micro servo from a guy for 30 bucks US + tax..
-Scott
MicroSizers:
Red Lancer (27)
Yellow RX-7 (49)
Black Celica (27)
White Impreza (49)
Old 10-19-2002, 02:26 AM
urq435's Avatar
urq435 urq435 is offline
I would say getting a HiTec HS-85MG mini servo, $30, which has metal gears and bearing. Better than HS-81. Then, I would get LRP Quantum Micro Reverse ESC, $90, or Novak Spy Micro ESC, $56. For Radio Tx & Rx, I would suggest KO Propo EX-1 Mars-R, $240, or any pistol style radios you can afford but trying to get a micro size recevier. I would choose FM or PCM radios instead of AM radios. Also, you should get full bearing set for your MID kit. If you get an extra money, I would upgrade to 7.2v NiMH battery pack and Team Orion Elite Coreless modified motor. I would also get a 9T steel pinion.
Old 10-19-2002, 03:16 AM
urq435's Avatar
I might be wrong on pinion gear. I was using 9T for my micro. It might not be the case on MID.
newbie nrd123 ZipZaps Monster Truck 2 01-29-2006 06:57 AM
Ok, Just Stumbled in Here, I am Hooked where to Start?? TOTAL NEWBIE WARNING!!!! Ziptar TTTT 3 12-19-2005 12:37 PM
Newbie Zip Zap Fan Rusted ZipZaps SE 1 07-03-2005 03:30 AM
Newbie on the forums.....throw me in te right direction if ya hafta mustang_steve Bit Char-G / MicroSizers 4 10-18-2002 01:52 AM
quick newbie question bojangs Bit Char-G / MicroSizers 2 10-06-2002 12:44 AM
