Old 11-23-2003, 05:37 PM
Hugopolo Hugopolo is offline
Send a message via AIM to Hugopolo
Help i cant work my car
Ok guys im trying to get help here. I am trying to install the awd kit and im having trouble. For some reason the axel bar keeps moving inside the car causing the gears to spin inconsistantly. Does anyone know how to stop this.
Old 11-23-2003, 05:38 PM
M706 M706 is offline
somethingmorethannothing
Send a message via AIM to M706
that part is not needed in the AWD upgrade....and btw, why did you take the entire car apart???
Old 11-23-2003, 05:42 PM
I got that pic from a site just so i could show u what part im talking about
Old 11-23-2003, 05:45 PM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
did you ask them for permission about using the pic?
All Wheel Drive=Fun!!!
Old 11-23-2003, 07:12 PM
viperkilla's Avatar
I think that that part goes between the front 2 tires.
Old 11-23-2003, 08:56 PM
security civic security civic is offline
sleeper mall civic
Send a message via AIM to security civic
hmm that looks kinda like what my car looks like right now yeah that part isnt needed in the awd
douglascounty!!!
Old 11-24-2003, 03:56 PM
OK so the black piece isnt the problem does anyone have a differeent suggestion becuase i dont see why the gears and the bar are both moving
Old 11-24-2003, 04:04 PM
sleeper mall civic
do both rear and front wheels turn when u hold it off the ground if u got it on the ground and the motor turns but the wheels dont check the drive shaft to c if it is in the gear all the way
douglascounty!!!
Old 11-24-2003, 04:07 PM
no it turns fine, the wheels spin and the car works for like 1 minute until one of the gears missaline and then it studders
Old 11-25-2003, 11:40 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
do you have anything stuck in the gears?
NEVER UNDERESTIMATE THE POWER
Old 11-25-2003, 02:13 PM
Nope but i have another question( i wanna ask before i try is) is there a chance that my actual bar is back wards maybe? or is it the same ion both sides?
Old 11-25-2003, 02:18 PM
SonicKuz SonicKuz is offline
Send a message via AIM to SonicKuz Send a message via Yahoo to SonicKuz
If it is binding up, then I'd suggest taking it apart and regreasing the differentials. If it turns weak, make sure the axles are pushed into the differential correctly. If it isn't, it may still spin but really won't deliver any power.
What goat?
Old 11-25-2003, 04:34 PM
dragon4450's Avatar
customanix
hey is it possable that when you put it back together you put it on the wrong wheel setting? cos if you did that would make it so that the drive axel isnt sitting right.
Old 11-25-2003, 06:09 PM
What do you mean by wheel setting becuase i could have
Old 11-27-2003, 01:44 PM
aperson's Avatar
i think Dragon4450 means the wheel base setting
will 1/24 slot car parts work ? catman25 Mini-X Parts and Hop-Ups 3 01-30-2003 07:54 PM
antenna idea, bummer it doesn't work... john ZipZaps 5 11-07-2002 09:17 AM
Help ! New Bit Char-G doesn't work :( DJ_Mo Bit Char-G / MicroSizers 11 11-01-2002 02:18 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 12:59 AM
