11-22-2003, 06:47 PM
Ugh mines all scrwed up some1 help me!
Ok so i was messing around with my xmods and i had stage 2 drift motor with soft tires and whenever i would turn the tires had a way of slipping off the wheel so i well, glued the tires on the wheel so i could drift like mad. Shortly after this my car started going REALLY REALLY SLOW but the motor was doing max revs. When i got my car off the ground and turned one of the wheels the other wheel didnt turn which means something is slipping differential wise. So today i bought the AWD kit cuz it comes with another back differential. I put it in and well still doesnt fricking work, tried over and over added grease everything it just is fricked up.
Any ideas im desperate.
11-22-2003, 07:29 PM
I KNOW NOTHING!!!
Heres what I do when I have a problem like that.
I start at one end of the driveline, motor pinion is a good place to start by making sure it doesnt slip and closely look and test each part untill I find the slipping/broken part.
You dont have to take the whole car apart (then again you might) you just have to verify each piece.
11-22-2003, 07:50 PM
got boost?
and also check if there is any hair or dirt
All Wheel Drive=Fun!!!
11-22-2003, 08:36 PM
I'm not a pyro, really.
if you got ball bearings make sure one of them didnt sieze. that happend to me yesterday. i would take the whole rear end out and thoroly clean everything to make sure.
NEVER UNDERESTIMATE THE POWER
