Old 11-19-2003, 03:04 PM
JediYoda56 JediYoda56 is offline
Send a message via Yahoo to JediYoda56
ZZ vs ZZSE?
Hi all,
Been away from ZZ for awhile . Went into Radio Shack to see the new xmods and noticed the new ZZse's.
I was wondering if anyone can tell me what the difference is between the 2? Or is there some sort of online faq with the info? Are the parts interchangeable or the new controllers?
Any help is apprciated.
Thanks
LV
Old 11-19-2003, 03:20 PM
SuPeRdUdE SuPeRdUdE is offline
the se has propo steering and throttle, and a new controller
If i was atacked by a rancid 5 legged monkey, i would put him in the fridge until he clamed down. Then i would ask him what happens to the light when you shut the door.
Old 11-19-2003, 03:32 PM
viperkilla's Avatar
Well, I think that pretty much all the parts are interchangable. The difference is that the controller is a pistol grip. There is proportional steering and the bodies come with lights installed. As for the bodies they stand really high on the chassis and the chassis is totally redesigned and you can save any batteries that you dont use by using the switch on the chassis. Also you can race up to 6 people. Hope this helps!
Old 11-19-2003, 07:26 PM
Woudl you say the SE are better or worse? What is this thing about them being slow? Have they chagned the orginal ZZ at all?
Old 11-19-2003, 08:07 PM
viperkilla's Avatar
Well it depends what you mean by better. They are alittle slower than normal ZZ because of all the new electronics and stuff. What do you mean by "have they changed the original ZZ at all"?
Old 11-19-2003, 08:48 PM
rfnagel's Avatar
rfnagel rfnagel is offline
Send a message via AIM to rfnagel Send a message via Yahoo to rfnagel
The new Shale Green Jeep Wrangler has suspension springs (similar to the SEs) in place of the suspension bar, but so far only that specific model of original ZZ has them. I think that any future original Zaps that RS releases will come with new suspension springs though -
Old 11-19-2003, 09:09 PM
Are they better as in more fun or anything like that? Are there any new upgrades for the old ZZ now as well? Thanks for th answers all.
Old 11-20-2003, 02:11 AM
carlisimo carlisimo is offline
Send a message via AIM to carlisimo
The SEs have really cool features, but are inconsistent. Don't buy one if it's too much of a hassle to return to the store for an exchange; from my experience only, 50% of them don't turn well at all (the real number probably isn't that bad).
They have lights, supposedly proportional steering and throttle (turn the steering wheel halfway and the car does a shallower turn; pull the throttle trigger halfway and the car goes at half speed), and most importantly, six cars can race at once (in theory you can race 6 SEs and two regulars at once).
They're a bit slower and the bodies are higher on the chassis (looks ugly) but I think they're worth the $5 increase and more - if you get one that works. So again, if you don't mind returning a defective one, go for the SE.
The engine/gear upgrades work on both versions. Some of the non-SE bodies have trouble fitting on SEs, and SE bodies probably need the lights removed to fit on a regular chassis.
Old 11-20-2003, 03:26 PM
just get the se
Old 11-21-2003, 02:50 PM
Lord_HelmetR34's Avatar
Lord_HelmetR34 Lord_HelmetR34 is offline
Bit Crazy
If you get one, make sure you check out Micro_Amps mosfet mod.
Carlisimo is right, the bodies do sit high on the chassis, but It's a minor thing. A little cutting will bring it down to a suitable level. And some wheels are definitely in order.
For example:
Dubshop Customs
ZZSE many modding questions mcbradshaw ZipZaps SE 24 11-03-2004 12:28 AM
best zzse HebrewHammer ZipZaps SE 6 12-18-2003 05:09 PM
Guitar String Antenna for your ZZSE ph2t ZipZaps SE 4 12-05-2003 08:56 PM
4.8 Volt ZZSE urbanavenger ZipZaps SE 2 10-03-2003 11:13 AM
Did some comparisons between ZZSE / Bit Clones today... ax0n ZipZaps SE 9 09-30-2003 05:27 PM
