Old 11-17-2003, 07:59 AM
neurokinetik's Avatar
Thumbs up Make a true limited slip differential
Tried this last night, and it works!
Since the differential units on these cars are completely enclosed, it is very easy to disassemble them and fill them up with grease to stop them from rotating as freely. Yes, that is correct. Use grease to stop things from moving as freely, rather than making them move more freely. What I did was load up one of the diffs with as much grease (from the AWD kit, I couldn't find my tube of bicycle grease that I really wanted to use) as it can hold. If you add enough, the diff will act as though it is "welded", and will hardly slip at all. By using more or less grease, and possibly changing the type of grease used, it is possible to vary the amount of slip that the differential allows. This seems to be a better alternative than the ball diff, which seems to have a clutch-type action no matter how much I tighten it.
Old 11-17-2003, 08:24 AM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
huh, interesting, didn't think of that. i tried the same thing with the ball diff last nite and it slipped less. i used the grease from teh awd kit.
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-17-2003, 12:42 PM
crazydave's Avatar
Garage Rocker
Used to do that in my 1/10th scale Traxxas Stampede. It is definately a tried and proven method for tuning gear diffs.
Try different thicknesses of grease.
I've found 'Green Slime' works great. Most LHSs with RCs carry it.
I just wanted to add that while this slows the differential effect, it is not 'true' limited slip. A true limited slip ball diff actually allows little bit of slip, this prevents torque from breaking traction.
Old 11-19-2003, 09:25 AM
mbartell mbartell is offline
so I re-wired it
Reversable Locker
The grease in the diff works great!
But if you don't want any differential action at all, like for straight line drag, lock it up.
Take apart your stock gear diff, and pack silly putty in around the gears inside. just use a little bit, and screw it back together. Your diff shouldn't move.
You remember playing with silly putty, right? it bounces and reacts to any hard impact with a lot of resistance, but flows or stretches when you pull it slowly. This is why it works in the diff well to jam the gears up.
The silly putty keeps it all in one place, and if you want to go back to normal, it cleans up a lot easier than glue or epoxy.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 11-27-2003, 11:39 AM
GhettoFiedRacin's Avatar
GhettoFiedRacin GhettoFiedRacin is offline
you are not your xmods
Send a message via AIM to GhettoFiedRacin
wuts the point of a limmited slip diff.... does it increase speed?
I like the way you drive. Hittin walls and bouncin on the sides. Cuz the glare off my rims hit ur eyes
Old 11-27-2003, 11:52 AM
crazydave's Avatar
Garage Rocker
No, if anything it might kill off the line acceleration. It makes your car more controllable with really fast motors, because it helps eliminate wheel spin.
Packing the gear diff with grease doesn't make it limited slip, what it does do is, when you making a hard turn, and one wheel lifts, it will unload, and put no power to the other wheel. Packing the diff helps transfer the power to the other wheel, so the lifting wheel doesn't unload as bad. I was just playing today, and decided that this is a 'must do' if your gonna use the stock diff.
Old 11-27-2003, 02:51 PM
Hairball Hairball is offline
Cheese Ninja
Send a message via AIM to Hairball
I did the same thing to my differential... but I used chewing gum, so it works better and smells minty fresh!
ThisonetimeIwaslostinthewoodsandIsawthisguywhohada steakandIwaslikewhoa.
Old 01-08-2004, 01:21 AM
spinitsidewayz!'s Avatar
boro dori style RC
try making a "paper" clutch type lsd
http://www.tinyrc.com/forums/showthr...threadid=17285
Old 01-08-2004, 05:36 PM
LithiumXmod LithiumXmod is offline
nice, i will try this later.
LithiumXmod
Mods:
4 Cell CR2's Photo Lithium Batteries
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Suspension - Front: S Rear: H
Steering - 1.5 degree Tie Bar
Coming soon:
Ball Bearings
The Ball Differential: LSD, USD, or LGD? Turnination Guy XMODS Parts and Hop-Ups 0 02-03-2005 12:29 AM
limited slip? no!! Shiporu XMODS 6 03-20-2004 12:26 PM
AWD question (need answer quick) 93Supra0wner XMODS Parts and Hop-Ups 7 12-30-2003 02:53 PM
locking differentials turbopimp187 XMODS Parts and Hop-Ups 11 12-15-2003 07:36 PM
limited slip diff.. Kingofjapan Bit Char-G / MicroSizers 14 12-18-2002 04:17 PM
