11-12-2003, 04:00 PM
wide right turn
on my xmod if i turn left i basically can do all these donuts and stuff but if i turn right my turn is super wide can anyone help me
11-12-2003, 04:03 PM
Hmmm...something is definately wrong here. Make sure that the throttle trim is set to low. This will give you a better turning radius. I dont have much expertice in this field. So I think that other people may know what is wrong.
11-12-2003, 09:34 PM
i posted about this in another thread but it seams alot of ppl with AWD have wide right turns including myself
11-12-2003, 10:06 PM
I think thier cute!
i dont... i have allwheel drive... try installing your stock rear diff it may help...
11-12-2003, 10:53 PM
Got 4.2 King? I do : )
yeah my turns are fine with stock differentials all around
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
11-13-2003, 08:32 AM
i figured out how to fix the AWD problem. if you put the stock A arms in the front and back that should fix it. thats what fixed mine
11-13-2003, 09:17 AM
THe AWD replacement A-arms on the front have increased caster so the turns are a bit less sharp, but more manegable.
Also the LSD (limited slip differnetial) in the AWD kit is very stiff so it pushes the front through turns (understeer or pushing).
Steve
11-13-2003, 02:49 PM
i put in the stock rear diff. and it works fine now thanks
11-16-2003, 03:32 AM
Left
Yea I found that the left rear suport arm Is the cause of the problem It is turend in So the back pulls to the right
Martin
11-16-2003, 03:04 PM
Hey i have the same problem, except that its my left turns that are wide, i dont understand it. whenever the batteries are fully charged its better, but i can only drift and everything turning right, and i have the 3 tierod, blue in the front and red in the rear, and i dont understand it
11-16-2003, 04:27 PM
0reZepyT
make sure all your wheels spin freely. misaligned bearings/bushings, hair, and/or dirt can affect the turning ability. oh yeah, many awd kits have front A arms and rear swing arms that aren't made very well and thus limits suspension travel, just FYI. i stuck with the stock arms
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
11-16-2003, 08:16 PM
but the red ones if made right make the suspension feel softer or something
11-16-2003, 08:47 PM
0reZepyT
it does? it's supposed to be identical other than color and lack of quality control
11-18-2003, 11:43 AM
Steve
if you lube the LSD with the gear grease it works great
11-18-2003, 12:46 PM
I fixed my steering by shifting the batteries to the rear and soft springs front, hard rear. I have the AWD installed.
