Old 11-12-2003, 05:00 PM
CurryITR CurryITR is offline
wide right turn
on my xmod if i turn left i basically can do all these donuts and stuff but if i turn right my turn is super wide can anyone help me
Old 11-12-2003, 05:03 PM
viperkilla's Avatar
Hmmm...something is definately wrong here. Make sure that the throttle trim is set to low. This will give you a better turning radius. I dont have much expertice in this field. So I think that other people may know what is wrong.
Old 11-12-2003, 10:34 PM
Lucid Dreams
i posted about this in another thread but it seams alot of ppl with AWD have wide right turns including myself
Old 11-12-2003, 11:06 PM
_revhards13 _revhards13 is offline
I think thier cute!
Send a message via AIM to _revhards13
i dont... i have allwheel drive... try installing your stock rear diff it may help...
Old 11-12-2003, 11:53 PM
Got 4.2 King? I do : )
yeah my turns are fine with stock differentials all around
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 11-13-2003, 09:32 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
i figured out how to fix the AWD problem. if you put the stock A arms in the front and back that should fix it. thats what fixed mine
NEVER UNDERESTIMATE THE POWER
Old 11-13-2003, 10:17 AM
FESCSteve FESCSteve is offline
THe AWD replacement A-arms on the front have increased caster so the turns are a bit less sharp, but more manegable.
Also the LSD (limited slip differnetial) in the AWD kit is very stiff so it pushes the front through turns (understeer or pushing).
Steve
Old 11-13-2003, 03:49 PM
i put in the stock rear diff. and it works fine now thanks
Old 11-16-2003, 04:32 AM
martin3103's Avatar
martin3103 martin3103 is offline
Send a message via Yahoo to martin3103
Left
Yea I found that the left rear suport arm Is the cause of the problem It is turend in So the back pulls to the right
Martin
Old 11-16-2003, 04:04 PM
Chad Rump Chad Rump is offline
Send a message via AIM to Chad Rump
Hey i have the same problem, except that its my left turns that are wide, i dont understand it. whenever the batteries are fully charged its better, but i can only drift and everything turning right, and i have the 3 tierod, blue in the front and red in the rear, and i dont understand it
Old 11-16-2003, 05:27 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
make sure all your wheels spin freely. misaligned bearings/bushings, hair, and/or dirt can affect the turning ability. oh yeah, many awd kits have front A arms and rear swing arms that aren't made very well and thus limits suspension travel, just FYI. i stuck with the stock arms
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-16-2003, 09:16 PM
aperson's Avatar
but the red ones if made right make the suspension feel softer or something
Old 11-16-2003, 09:47 PM
TypeZer0's Avatar
0reZepyT
it does? it's supposed to be identical other than color and lack of quality control
Old 11-18-2003, 12:43 PM
aperson's Avatar
Steve
if you lube the LSD with the gear grease it works great
Old 11-18-2003, 01:46 PM
Racer240's Avatar
Racer240 Racer240 is offline
I fixed my steering by shifting the batteries to the rear and soft springs front, hard rear. I have the AWD installed.
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 08:35 AM
making car turn better using tape rydzjunior XMODS 6 01-04-2007 11:53 AM
The Wide Sweeper is BACK! Steve ZipZaps SE 10 09-30-2003 09:15 PM
Really wide turns on my clone Darius2250 Bit Char-G / MicroSizers 6 03-22-2003 11:57 AM
wheels turn but car wont?? Spanky Bit Char-G / MicroSizers 4 02-24-2003 02:54 PM
