10-28-2003, 09:49 AM
so I re-wired it
parts I'd like to see
Here's a list of aftermarket parts that I think should be made:
Long throw servo horn
adjustable motor mount to allow for more gear ratios
solid metal rear "axlebones"- they are half plastic!
a mini z style turbo add on, for more powerfull motors
High quality low resistance AA battery holders
Heat sinks for the batteries, like the mini z
carbon or titanium shaft kit- all 3 lengths
better ball bearings
camber changing upper arms
a kit to use the 4wd set up in the back
and that's not even geting into chassis parts.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
10-28-2003, 10:27 AM
This is thinking very big but i would like to see a drag strip and courses for the xmods. I mean we could all make a custom one but it everyone had sort of a regulation drag for these cars, then times would be able to be compared easier.
I would def like if diff cars came out......an evo, an sti, more new cars........a 67 impala, a stingray, more old cars.
Another thing is more body kits so everyones cars are different. I mean i know u can paint your cars but if it is the same style as even one persons car, it makes it less fun.
Also replacement parts.
Metallic blue supra, wild body kit, stage two 10 teeth motor, metal bearings, tire upgrade, suspension upgrade (hard all around with 1.5 tie rod), light kit, XS rims.
10-28-2003, 06:31 PM
mini-eX-Driver
a front one-way diff
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
10-29-2003, 12:33 AM
I have a beach ball...
A front one-way would be sweet.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
10-29-2003, 09:37 AM
I'm not a pyro, really.
id like to see a 1/4 inch lift kit even a 1/8 inch would be good. id also like to see a skid plate from RS.
NEVER UNDERESTIMATE THE POWER
10-29-2003, 09:46 AM
10-29-2003, 09:54 AM
so I re-wired it
lower a-arms. I can't think of a cooler way to get more suspension movement. Cut off the tabs on the chassis, and there you go.
That's how you would do the lift kit too. Longer a-arms and a simplified sliding shaft like on the 1/10 scale traxxas trucks.
Ball joints on the top and bottom.... Hmmm I need to start drawing something up.
Famous last words:
10-29-2003, 04:31 PM
like my dog??
i would like to see some type of rally kit. it could have alift kit and some rally tyres. mabye even a dirt sheild for the chassie
--Chris
Aka...aero528
10-30-2003, 11:26 PM
Yeah with a subaru wrx body that would be sweet!
also New Mirrors PLEASE!
and kits with more than just four leds
-=Cy
10-31-2003, 06:53 PM
Go Banana!
yes i would buy like 2 more cars if there was a rally kit and the rally bodies. Since I'm a wrx owner i really want that body badly. A peugot 206 body would be very cool as well....hell any of the wrc car bodies would work except i'd be in debt from buying them all.
New mirrors as well, one is off and the other hangs by a molecule.
I would definitely buy any tinyrc parts you come up with as well as your chassis kit slugbugg
11-01-2003, 03:23 AM
the "too many tires" guy
Best thing in my mind would be a chassis that is designed around keeping cruft out of the gears. i guess that means having enclosed front and rear boxes around the transfer gears. i understand that a tie rod won't be able to work enclosed, but at least the amount going in would be reduced greatly.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
11-01-2003, 09:13 PM
parts
How about a titainium or aluminum screw kit? I think there are like 5,000 screws on these things! I bet it it would drop a few grams off of the weight of the car. Just an idea..............
11-05-2003, 04:04 PM
bitPimp
Top on my list would just be replacement chassis parts, like steering knuckes. I don't want to have to buy a whole new starter kit when one small part breaks.
11-06-2003, 03:48 PM
replacement parts
titanium screws
aluminum body styles
11-11-2003, 04:56 AM
sumkinda digital nitrous. like small batteries that are incased in a nos bottle with a braided wire to the motor for a realistic look and feel. maybe real anodiezed steel sway bars instead of ppl making them outa paper clips n stuff. o, and colored chasis kits, so u can get interior apperance. more body kits and more rims.
