Old 11-11-2003, 01:04 AM
turbopimp187 turbopimp187 is offline
all-wheel drive
i heard that getting the all-wheel drive kit decreases top speed. doez it really slow u down or iz dat just a rumer?
Old 11-11-2003, 01:29 AM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
It does slow you down but not much if you leave the stock (white) differential in the rear. The payoff is greatly increased handling.
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-11-2003, 04:35 PM
thankx
Old 11-11-2003, 05:36 PM
weba2nkill3r weba2nkill3r is offline
teenage r/c maniac
Send a message via AIM to weba2nkill3r
Is it good to get a awd?
Old 11-11-2003, 08:26 PM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
Yes!!!
All Wheel Drive=Fun!!!
Old 11-11-2003, 08:45 PM
viperkilla's Avatar
Like Hudson5150 said, your speed slows down alittle bit but not too much. But this gives alot of handling.
Old 11-17-2003, 02:18 PM
Stormvet's Avatar
Stormvet Stormvet is offline
Paint X-fer?? UP YOURS!
I've noticed that the speed has reduced minimally but the biggest drawback I've seen is that my turning radius has decreased a LOT! If I want to make a sharp turn I need to slow WAY down. I'm running soft tread tires, hard springs in the rear and soft springs in the front.
The BIG plus to the AWD kit is that you don't spin out (oversteer) nearly as bad.
StormVet
Freedom will be defended!
2003 RSX - Silver
Stage 2 (Blue)
Bearing upgrade
Suspension Upgrade (Hard rear - Soft Front)
Tire Upgrade (soft treaded)
AWD
Modded with alt-flashing red & blue LED's (Police lights in grill)
Xmods _FRONT_ Wheel Drive Daedalusleto XMODS Mods and Projects 7 05-16-2004 09:29 AM
In need of an All Wheel Drive kit, Command Logic Light Kit, Ball Bearings, etc.? RC 2NR XMODS Parts and Hop-Ups 4 02-25-2004 06:54 PM
FWD XMOD!! YES! Front Wheel Drive!! MicroRCracer XMODS Parts and Hop-Ups 60 01-14-2004 03:32 PM
