11-06-2003, 07:31 PM
Bit Crazy
When I start to slide, I apply a little reverse lock by tapping/releasing the steering button very quickly. This helps keep me from overcorrecting and spinning out. Dust on floors is awesome for drifting no matter what tires you may be running
11-07-2003, 06:07 AM
R34 Skyline is God
wouldn't the dust come off eventually? I still think theres some other thing I can put on the tires to drift.
11-07-2003, 07:56 AM
not really... you actually accumulate more and more if you don't clean up. That's what happens to my car.
11-11-2003, 02:04 PM
R34 Skyline is God
New drift method!
I jsut thought of this a couple of days ago: Put tape on your tires! Alot of tape is so smooth you may be able to get your car to drift really well! Scotch tape is what I am going to use.
11-13-2003, 04:46 PM
Do not tape the whole tire!
put a very thin strip on ALL four tires. Get some electrical tape and devide it length-ways 4 times. In half, then that half, in half etc. It also helps to have a little more weight at the back. This shifts the C.O.G further to the back. If you wanto see the results, check alittle earlier in these posts and you will see my drift vid.
The use of verylittle tape is so that the tires can break traction but not lose all of it.
Hope that helps.
11-14-2003, 06:09 AM
R34 Skyline is God
Will scotch tape work though? By the way thanks.
My Bit: Phast motor  (Orange)
Soon to come:  (Undecided) Custom Rims
11-14-2003, 04:32 PM
I have never used scotch tape. But I guess it would work.
Glad to help
11-14-2003, 04:45 PM
R34 Skyline is God
Can I cut the tape instead of fold it?
11-23-2003, 11:21 PM
Of course you cut it. It wont stick if you fold it.
12-25-2003, 07:14 PM
I haven't been able to drift yet but I can power slide through my turns and that looks about the same as drifting through a turn so I'll post my settings for my car
AE86 shell
2speed chassis
2.2 micro b motors
clone slicks on back wheels
hard tires in front
some dust
12-29-2003, 08:31 PM
5Zigen
mine is:
Mitsu LanEvo IV (silver)
"BOOSTER" chassi
front slick med
rear panther plasticy rubber hards
3.4 with orange gears
soft stabilizer bar
Try And Sleep Now.
DRIFT my ANTI-rice
01-17-2004, 02:53 AM
otobots transform!
DRIFTIN'
hey! newbie here n totally into driftin...
i hav a booster set from d auto modelista set...
my specs are...
stabs - stock
gears - 9:86:1
engine - 3.0
rear - hard
front - soft
i change my body from time to tim, but im usin d evo7 rally ryt now...
driftin - ol u do is hit d boosts, den wen its fast enuf, let go of d acceleratin n turn...woosh! n der u go, u just drifted...
02-03-2004, 01:33 AM
Ooo I noticed you have been posting a lot on this topic...
You want stretched out tires? Use front tires on the back axles!!
02-11-2004, 06:04 AM
otobots transform!
i went for the easy way...i bought d drift set...har har har!!
02-13-2004, 03:28 AM
RE: Bit Char-Drift
My car was set up:
-Car: red AE86
-Freaquency: 35MHz Booster
-rear: drifting wheel/axle
-front:custom from drifting wheels (moded fromt drifting wheel/axle)
-motor: 4.2
-stablizer: medium
I got a video that I made http://www.imagestation.com/picture/...6/f9b75658.mpg I use salt as gravel to make the car slide
"Stop being such a pu$$y!" Arnold S.
-Zenki Corolla GTS (coupe)
<img src="http://www.imagestation.com/picture/sraid71/p1a49c9002793c24d3305d7070f0044dd/fb9b4212.gif">
