Old 11-06-2003, 08:56 PM
Bad Company's Avatar
6 Cell Mod...7.2V
OK, I broke down and did it anyway...without regard to any damage that might occur. I have only tested this in the kitchen cuz it's raining outside. From the drag race tests I have done, all I can say there is a big difference. The tests were done with bone stock cars, and fresh batteries in both (even switched the batteries to one another.). The 6 cell far out accelerated the 4 cell. I hope to do some extensive testing tomorrow outside. I want to get a durabilty test to see if the electronics can withstand it. I have let the car sit here powered up for 30 minutes now with no signs of overheating, etc.
If all goes well, I WILL find a way to fit these in the body!
Old 11-06-2003, 09:11 PM
JesterDotcom JesterDotcom is offline
3D Racer
cool
Old 11-06-2003, 11:08 PM
dEmOnRaCeR's Avatar
"Its OK I had subway"
can u take a pic of the where the wires r going cause i want to try to do this
Old 11-07-2003, 12:12 AM
FLMX647 FLMX647 is offline
when u figure it out please post a step by step
Old 11-07-2003, 04:58 AM
I just cut the wire running from the negative on the left side over to the positive on the right side. (black wire on the bottom) I then ran the negative from the left to the positive on the new pack, and then ran the negative from the new pack to the positive on the right side.
Like this, the body will not fit on, but after I confirm the car will take long extensive use like this, I will mod it so the body fits.
Old 11-07-2003, 05:33 AM
catman25 catman25 is offline
I have done this big whup...jopking ofcorse i have done this and i found a key to making the body fit.cut the lighting system posts and move the lighting system to any one screw thats out of the way..If you use a hair dryer you can manipulate the shape of the body with out effecting th paint and its not very noticable..I have the supra .probly the tightest fitting one and that resulted in just making a scoop on the winshield.,seeing how its bLACK ITS not noticeable.I heated the body up past hand burnong point(wore gloves)and you have feel it bending easy i put the body back on while still hot and press down hard..this formed room for the holder.then just leave it there till cool and walla.The plastic of the batt holder wont melt as easily as the body,and its not reaLLY Melting the body just making it more pliable.There is no running of paint or creases.Dont have a cam just my experiances
Old 11-07-2003, 07:41 AM
neurokinetik's Avatar
When you have so many spare cars, what's to worry if you blow one up? :lol:
Just get a Mini Cooper body and it'll fit fine...
Old 11-07-2003, 01:16 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
did you try 5 cells first or did you jump straight to 6 cell?
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-07-2003, 01:26 PM
5 rechargables equal same volts as 4 alkalines..so no went straight to 6 cells.
Old 11-07-2003, 02:53 PM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
wow looks great i heard that the electronics can handle it well see
All Wheel Drive=Fun!!!
Old 11-07-2003, 05:21 PM
dEmOnRaCeR's Avatar
I hope the results r good i hope it doesnt like crash and burn cause rite when results come out im gonna do this 4 sure
Old 11-07-2003, 05:46 PM
Ive been running a week at 7.2 and no probs yet
Old 11-07-2003, 05:48 PM
I went straight to the 6 cell, for the reason mentioned above, the 5 cell NiMH only gives the power of 4 alkalines.
Old 11-07-2003, 06:09 PM
TypeZer0's Avatar
0reZepyT
it may match the voltage of 4 alkalines but nimh and nicd can dump out more current than alkalines, that's why 4 nimh is already faster than 4 alk's
Old 11-07-2003, 07:21 PM
you have a point there..but over all nicads push the most ..but dont carry the constant volts for as long..
Tri cell mod. RobotGT Tips, Mods and Reviews 1 02-24-2010 04:27 AM
Tri cell mod RobotGT Bit Char-G Mods and Projects 5 09-25-2003 04:22 PM
Tri cell mod RobotGT Bit Char-G / MicroSizers 3 07-27-2003 11:06 AM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 09:57 AM
