Old 11-03-2003, 05:15 PM
kingcobra kingcobra is offline
well...
stay away from plasti cote spray paint!!! it ate the factory paint and melted my body!!! now I need to remove the paint, sand and fill the body to fix all the melted parts and try to repaint it...IF its repairable...since the replacement bodies aren't available yet. this sucks.
Old 11-04-2003, 04:56 PM
viperkilla's Avatar
Re: well...
Ouch that must suck. Are you going to use putty to fill in the holes?
Old 11-04-2003, 06:01 PM
ya...
almost got the body back to a "paintable" state...pics soon...will have to get the body kit now as the stock ground effects are ruined ( the paint melted them beyond repair) so I might as well paint it all together with the new body kit on it.
Old 11-05-2003, 07:31 PM
well...
after a good bit of sanding and using plastic polish I got it smooth again...and the body kit is installed. now to find a paint that doesn't screw up when applied to the factory finish or strip the paint off the ground effects...
Old 11-05-2003, 07:32 PM
another...
pic 2...
Old 11-05-2003, 07:33 PM
another...
pic 3...
Old 11-05-2003, 07:34 PM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
cool,looks ready for paintjob
All Wheel Drive=Fun!!!
Old 11-10-2003, 09:15 PM
ok...
here it is painted...but I haven't painted the windows or lights yet...also it is no longer on my x mod chassis...it's now on my mini z...
Old 11-10-2003, 09:53 PM
vi3ti2avei2's Avatar
vi3ti2avei2 vi3ti2avei2 is offline
Projekt X
Wow!!
WOW!!! dang.. give u props man.... many many props.. nice paint job.. what color?? is it the same as paint'n like.. lexan bodies.. cept the opissite way??
I aamm Back!
Old 11-11-2003, 10:15 PM
done...
all thats left to do it install my light kit...all the intake holes and vents are painted flat black but you can barely see it in the pic because of the dark paint...
Old 11-11-2003, 10:17 PM
I think I will put LED's where the real fog lights go...pics soon...
Old 11-12-2003, 01:42 AM
dragon4450's Avatar
customanix
man mad props. i love the color and i'm glad that you brought it back from the dead when the paint messed up on you.
Old 11-12-2003, 02:31 AM
Revlis Revlis is offline
What brand paint did you use that time?
Old 11-12-2003, 04:56 AM
Bad Company's Avatar
Nice! That is an excellent paint job! Awesome color and nice smooth glossy finish, one of the best yet. I like the wheels too.
Awesome job!
Old 11-12-2003, 06:10 AM
thanks...
thats a Duplicolor high temp wheel paint...graphite metallic...available at autozone...you must use Duplicolor scratch filler primer on the body and let it dry a day or two before applying the color or the paint will sink into the plastic and not be shiny...also to get it to shine like this you need to wet sand the primer and get it very smooth...I used 800 grit wet or dry sandpaper...and got this result. oh ya...this paint once fully dry is VERY durable and scratch resistant! thats why I chose it. I used it on my large scale custom built camaro a year ago and haven't seen even 1 scratch on it...
Finally! aperson XMODS 10 08-22-2007 05:38 PM
finally gorbasho XMODS Parts and Hop-Ups 0 03-30-2005 10:47 PM
Does the perfection light set fit inside a mazda rx7? Drag00n Bit Char-G / MicroSizers 9 01-07-2004 05:39 PM
I finally got one!! wohoooo Daazndood XMODS 4 11-23-2003 10:11 PM
Finally! I've defeated the Spam! Namuna Miscellaneous Discussion 1 09-13-2002 05:21 PM
