Old 11-04-2003, 11:11 AM
WytSoupBra WytSoupBra is offline
Skinny tires
I noticed that there are skinny tires on the Mini Z... I was wondering if I were to put skinny tires on the front of the X-Mod if I could get a tighter turning radius on it.. somewhere along the lines of the Mini-Z.
Old 11-04-2003, 12:17 PM
_revhards13 _revhards13 is offline
I think thier cute!
Send a message via AIM to _revhards13
probably not because the xmod has awd and it needs all the traction you can get in the front
Old 11-04-2003, 12:41 PM
awd is an option.... but I don't need to run with it... actually sometimes I prefer 2wd... but has anyone tried using skinny tires up front to see if the turning radius decreases significantly?
Old 11-04-2003, 08:23 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
skinnier tires = less contact patch = less traction and skinny tires in front increases understeer, making teh steering radius even larger. i suggest you setup the car for oversteer, make the rear suspension stiffer than the front, grippier tires up front and less grippy tires in the rear.
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-04-2003, 08:28 PM
Got 4.2 King? I do : )
if you drive fast you dont want understeer. the back end loses grip faster making you spin out. the less grip in the front should be an advantage
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 11-04-2003, 09:24 PM
TypeZer0's Avatar
0reZepyT
you mean you DO want understeer right? cuz understeer means your car "pushes" when turning and less grip causes the understeer.
i like to do a lot of curvy driving so i like having a lot of oversteer to swing my car around corners, helps make up for the large steering radius
Old 11-04-2003, 09:27 PM
i ment i wouldnt want over steer as much. but it depents what your doing. if you are running a slow motor and you can throw the end around turns with out spinning out its good. but if your just driving around ging fast your ging to find your self spinning out with oversteer. so it depends what your doing more than any thing else
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 11-05-2003, 11:17 AM
I get your point dude.. with the less traction idea... how did Kyosho overcome that with the Mini-Z? everyone else is confusing the crap outta me.
Old 11-06-2003, 07:43 AM
Cian's Avatar
Cian Cian is offline
Got Cheese?
the front wheels on the Mini Z turn more than the Xmod ( ie wider range ofsteering) , and the weight of the rear mounted motor kinda helps swing the car round
Lisa: And vice versa...
Old 11-06-2003, 09:06 AM
so why are the tires skinny up front on the Mini-Z? to counter the oversteering effect of the rear mounted motor (due to the larger contact patch area of the rear tires)? I like the mid mounted motor idea on the X-Mod... it's like the Associated TC3.
Old 11-07-2003, 11:06 PM
mustang_steve's Avatar
the "too many tires" guy
Well,having a tail happy car isn't all that bad, some of the fastest cars made in real life were very tail heavy....the 80''s porsche 911 turbo's come to mind as a very outstanding example. Rear-engine rear wheel drive, and gobs of power at that. Those cars were known for their difficulty to run through corners, but their overall performance was so good that they more than made up for it.
If you want massive understeer buty still be able to let the back end loose, make the car front wheel drive and put skinnies in the rear. It will be like pulling a throttle down drift on a real FWD car, just let off the throttle and the car starts to oversteer, put it back on and it moves towards understeer again. but you need to set your weight ratio properly to pull it off.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
Day's goodies and Cheap Foam Tires Jazz32 XMODS Parts and Hop-Ups 5 07-20-2006 12:01 PM
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 09:53 AM
best tires xxspeednplayaxx XMODS Mods and Projects 8 01-04-2004 07:24 AM
Tuning Basics sperry XMODS Parts and Hop-Ups 12 11-19-2003 01:56 AM
Bit tires vs Microsizers tires Dys70pia Bit Char-G Parts and Hop-Ups 3 12-28-2002 04:34 AM
