Old 11-03-2003, 06:37 PM
nosser nosser is offline
Send a message via AIM to nosser
video?
Murcielago659 what video are you talking about I haven't seen any video with a stage 10 by NML.
Old 11-03-2003, 06:43 PM
token5gtd token5gtd is offline
Send a message via AIM to token5gtd
yea, i looked on that site too, i didnt see a video
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
Re: video?
Same here.
I would like to see a video of this motor in action though. It would be nice to see what I'm getting.
The only video I've seen so far is of a hatchback with a AAbat mod.
____________________
Meh.
Old 11-03-2003, 07:17 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
i think he misinterpreted that video for one with the nml motor in the car. that would explain why he's not too impressed with it since aa batts wont make the car run faster...just longer.
Old 11-03-2003, 09:34 PM
PhillyB PhillyB is offline
so preorder? just let me know when to paypal - also where to send paypal
Old 11-04-2003, 09:29 AM
malform's Avatar
malform malform is offline
representing Deutschland
Send a message via ICQ to malform Send a message via AIM to malform
What? AA batts have more volts right? So more volts = more speed.
Old 11-04-2003, 10:08 AM
Heat's Avatar
aa batts and aaa batts are both 1.5 volts...aa batts have more capacity = more run time.
Old 11-04-2003, 10:11 AM
catman25 catman25 is offline
nihm recharges have 1.2
Old 11-04-2003, 12:24 PM
3series takumi's Avatar
mini-eX-Driver
aa have a higher amp rating than aaa. volt x amp = current. the total current runs the car so aa should be faster than aaa
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 11-04-2003, 02:50 PM
Heat's Avatar
aa and aaa alkalines have 1.5v
aa and aaa nimahs have 1.2v
so their charge is the same.
and for the other post...the different between them is ampere-hour capacity. the higher it is, the longer it runs. that's why a lot of things take both aa and aaa batteries cuz the difference is just the duration of it. i'm looking at this chart thing from batterieswholesale and it's telling me this. also, aa batteries weigh more so it would slow the car down. u can also refer to other batteries such as the nimahs from toyeast for bit char-g's. it only gives longer run times and does not make ur car go faster. which is why when i run my bits with a 100mah nimah battery it is as fast as a 200mah battery.
Old 11-04-2003, 02:54 PM
malform's Avatar
mmmm, i see... and here i was thinking about putting 4 aa's in my xmod, like a sucker :\
mini-eX-Driver
im not talkin about the mAh rating, i know thats capacity. i am talkin about actual output bud. if you have ever ran a micro rs4 on 5aaa then on 5aa you can easily see that it will run faster with the aa cells if you run with 5 a cells it will be way faster than the aa or aaa cells. cause the internal amp output is different on all the cell types (not the mAh). most r/c cells have the capacity as well as the amp output. aaa and aa usually dont.
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 11-04-2003, 02:57 PM
mini-eX-Driver
also, i tested my rs aaa cells and they are puttin 8amps out. my aa are puttin 12amps and the 2/3a cells (i havent tested) claim that they will put out 30amp with no drop on load
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 11-04-2003, 03:17 PM
Heat's Avatar
ooo u mean the discharge rate. my bad, yea it discharges faster but then u need a higher torque motor since they weigh a lot more than aaa batteries. the discharge is 3 times faster or around like 20 minutes but it is not that helpful in an xmod cuz it disrupts the balance in the car. might cause the wheels to dip.
Old 11-04-2003, 03:18 PM
Heat's Avatar
but i might get 1/3 aaa batteries instead but i dunno if the board can take it
MOTOR - NEW Design by NML for those who use Mini Z bodies MicroRCEngineering Kawada Tripmate Parts and Hop-Ups 1 07-04-2003 07:37 AM
Report on Motor Swap in MS Pro..... DarkTari Bit Char-G / MicroSizers 7 03-26-2003 08:45 PM
Motor Support Sub-Forum - Read This First! tinyrc TinyRC.com Motor Support 0 03-16-2003 08:38 PM
Clone Motor Mod marc515192 ZipZaps 5 11-01-2002 08:29 PM
Clone Motor Mod marc515192 Bit Char-G / MicroSizers 0 10-31-2002 04:19 PM
