Old 11-03-2003, 12:39 AM
_revhards13 _revhards13 is offline
I think thier cute!
Send a message via AIM to _revhards13
Ok, for ultimate traction
We have all notice that the AWD kit gives you slightly more traction but it does not use the Rear wheels efectively
Ive come up with a solution
Simply remove the RED LSD and install the WHITE lsd... it will make it so that when you spin the rear wheels the front will spin as well. you will loose some speed but it will make driving your XMOD alot more fun...
Old 11-03-2003, 01:14 AM
allahsone allahsone is offline
i am new to this but what is a LSD?
Old 11-03-2003, 02:28 AM
mustang_steve's Avatar
mustang_steve mustang_steve is offline
the "too many tires" guy
Send a message via Yahoo to mustang_steve
Limtited Slip Differential.
It's that white thing on your rear axle that allows for one wheel to keep turning with power while the other is stuck.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
Old 11-03-2003, 07:32 AM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
does it really work?
All Wheel Drive=Fun!!!
Old 11-03-2003, 10:31 AM
EMX's Avatar
EMX EMX is offline
I R r33t Hick
Send a message via AIM to EMX
Yes it does
I was surprised to see accuall LSD on these things.
Old 11-03-2003, 12:14 PM
I think thier cute!
but the Red lsd is realy a SD lol you can hold your rear wheels and let the front spin with my mod you can hold the front or the rear and neither will keep spinningthe diffs are actually diffrent not just the color like everything else...
Old 11-03-2003, 01:05 PM
I have a beach ball...
The white one is not an LSD, it's a regular open differential. Also you're not the first person to try this, I've had mine like this for about a week now.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 11-03-2003, 02:18 PM
catman25 catman25 is offline
what gains do you get for using thwe white one.I have yet to cross back im still using both reds?
Old 11-03-2003, 02:39 PM
You may not see any gains at all, if your ball diff is working properly. Some of us have noticed that the rear diff that comes with the AWD set slips way too much. If yours does this, you can swap to the stock diff and you would see some gains.
'65 Ford Mustang
All the RS goodies
Old 11-03-2003, 06:26 PM
with out sounding pethetic how do you notice problems? what to look for? Im used to mini x which is fully 4 wd
Old 11-03-2003, 06:36 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
I don't know what the problems are, I have the ball diff (red) in back and I can do nice powerslides, suggesting a rear tourqe bias. It is more a personal preference thing. I like the red ball diff.
Old 11-04-2003, 12:49 AM
Something you can try is to remove the front bevel gear, which effectively disables the AWD, making it RWD again. When you start it out, if you can hear the motor rev up but the car's not going anywhere fast, your ball diff is not working properly. If you can, return your AWD set and get a different one. If not, change the rear diff back to the stock white one. You really won't notice too much of a difference with the white one over the red one.
'65 Ford Mustang
All the RS goodies
Old 11-04-2003, 04:38 PM
3series takumi's Avatar
mini-eX-Driver
dont LSD lock up to a certain degree?
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 11-04-2003, 08:21 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
well, the lsd in these xmod's are ball diff type. the big center gear (forgot what it's called) holds several ball bearings in teh center. on either side are a couple of clutch plates which the drive shafts attach to. better ball diffs can be easily adjusted loose or tight to vary the amount of slip it allows
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-09-2003, 06:29 PM
YeLLoW GT-R R34 YeLLoW GT-R R34 is offline
Send a message via AIM to YeLLoW GT-R R34
Wow......Does it really affect speed?
Traction Compound Respect Bit Char-G Parts and Hop-Ups 1 11-13-2003 06:49 PM
need traction? westbitchopers Bit Char-G Mods and Projects 3 08-15-2003 08:18 PM
traction!!! misterbungle Dynamite Rocket Racer Parts and Hop-Ups 3 02-19-2003 03:02 PM
