Old 10-05-2002, 07:54 PM
henry's Avatar
henry henry is offline
13B REW
Exclamation 3.4 motor?
i was wondering if u guyz herd of a 3.4 motor? wat color is it? is it beter then 3.8? i kind of want a new motor cuz my cheap 3.0 motor sux .
Old 10-05-2002, 08:24 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
nope never heard...
get a real TOMY 3.0 for dependability
Old 10-05-2002, 09:31 PM
henry's Avatar
13B REW
minez is the real tomy 3.0 moter. its called bit racer and im havin a big prblem wit it . it dosnt go till i push it and wen it stops i have 2 push it again till it goes. any help will b fine.
Old 10-06-2002, 12:44 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
make sure u use the black pinion gear that goes on the motor...although it comes with a white one...dont use it....it seems that only is used for different gear axles...[i think]
Old 10-06-2002, 12:51 AM
E)(pul$ioN E)(pul$ioN is offline
Founder of EaT RiCe Squad
Send a message via AIM to E)(pul$ioN
Get the 3.8 BitChar-gMotor on eBay (Made by KC):
http://cgi6.ebay.com/aw-cgi/eBayISAP...sort=3&rows=25
Runs very well and no problems at all.
A student that doesn't like school.
Old 10-06-2002, 01:38 AM
323iT's Avatar
323iT 323iT is offline
the white pinion gear is used with bit racer's gears
DO NOT use that on your bit char-g unless you're running bit racer gears
Old 10-06-2002, 02:06 AM
henry's Avatar
13B REW
i do use the black and still it sux . so the 3.8 is good but a bit pricy and has a ugly color .pink. but if it handles well ill try 2 find a cheap price 4 the 3.8. . the 3.4 that i herd of is on this website : driftkingshop.com . youll find it there but it cost 20 $ . anyway any other solutions 2 my 3.0?
Old 10-06-2002, 02:36 AM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
Hey guys, well i found out a great motor which works in my bit and has LOTS O TORQUE!!! The ZZ RED motor!! This thing is sweet!!! I put ZZ wheels on the back of my bit and now my bit can pop the front wheels in the air of i go in reverse and slam it into forward (must warn you though, if you do this a lot you can damage gears and what not) But yeah this motor is awsome. I want to try out the yellow NOS motor now...
Old 10-06-2002, 04:33 AM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Lol, you prefer to not have a 3.8 cuz it's color is Pink? Who cares about the motor trim color, you can barely see it after placing the heatsink and the body on anyway. BTW i think I saw an OEM grey 3.8, which should fit your needs of non-feminine type colors.
Old 10-06-2002, 05:23 AM
henry's Avatar
13B REW
lol, i was jk about the color . well it did kind of look ugly in pink. where u but the grey 1s at? and r they good even if they r not tomy? or should i keep my 3,0 and try 2 figer whats wrong wit it? how come the 1.6 moter is so strong? it goes up hill and other motors cant. hmm could u go up hill wit 3.8?
Old 10-06-2002, 05:25 AM
henry's Avatar
13B REW
hey speed wtf is a zz red motor? any picz?
Old 10-06-2002, 12:35 PM
...and r they good even if they r not tomy? or should i keep my 3,0 and try 2 figer whats wrong wit it? how come the 1.6 moter is so strong? it goes up hill and other motors cant. hmm could u go up hill wit 3.8?
The 3.8 is not made by Tomy. The highest motor Tomy makes is 3.0 so far. You should get the 3.8 because there is probably no other way to figure out what the heck is wrong with the 3.0. With the 1.6, you can go up hills because it has lots of torque. The higher the numbers go, ie: 3.8 = Less torque, but more top speed. Therefore, you can't go up a hill with a 3.8.
Old 10-06-2002, 12:50 PM
cowfish_29's Avatar
yellow fish forever!
heh...well that tourque to speed thing does not always work with all motors. My 3.0 has more tourqe AND speed than any of my other motors...it just depends on your motor. If you get a good one, thank the bit char-g spirits for the gift!
Old 10-06-2002, 02:25 PM
SPEED's Avatar
SPEED IS GOOD
henry, the ZZ (or ZIP ZAP) motor is from radio shack. You can find info on them from the Zip Zap Forum. I got my motor with the booster upgrade kit. It also came with a blue motor, but that was to slow for my taste.
Old 10-06-2002, 03:26 PM
henry's Avatar
13B REW
is there a way to replace my 3.0 at ebay? e)(pul$ion thx 4 da tips but do u mean the lower the number the more torque? cuz i have a 1.0 and its very weak and very slow. is the 3.8 dependable even if its not made by tomy? any video of it going?
Real Motor Analysis backtrack9 XMODS Mods and Projects 8 02-05-2004 08:13 PM
Measuring Motor RPM backtrack9 XMODS Science 9 01-12-2004 05:00 PM
Motor Support Sub-Forum - Read This First! tinyrc TinyRC.com Motor Support 0 03-16-2003 08:38 PM
3.4 zip zap motor jerm781 ZipZaps 6 12-09-2002 11:01 PM
