Old 10-30-2003, 10:32 PM
lilcricket lilcricket is offline
Send a message via AIM to lilcricket
testors paint....
anyone had problems with testors spray paints? i used flat black as a primer on mine and the sapphire metal flake blue as the color coat, and it worked alright, but seems to take forever to completely dry....i'm still not sure if it's completely dry to tell the truth....it's been like 3 days...and it's obviously dry to touch, but it's very easy to scratch it...like it's not hardened or cured enough, anyone have any ideas? BC, i was thinking maybe you could help....
Old 10-30-2003, 10:42 PM
Bad Company's Avatar
Well, I've never used an actual color, even a flat for the primer. How long did you wait until you applied the top color? I don't know if maybe something with using two different colors without letting the first completely dry will have anything to do with it.
Old 10-30-2003, 10:50 PM
Savior*insider Savior*insider is offline
u might wanna clear coat it too.
I am the insider, i kno all
Old 10-30-2003, 11:48 PM
that was actually my next question...will clear coat harden...and protect that junk?
Old 10-31-2003, 02:19 AM
dragon4450's Avatar
customanix
i have noticed with testors spray cans that the paint will keep a tacky feeling for awhile. and no the paint does not harden. i would sugest going to like walmart or the like and picking up some dupli-color clear paint. i will give it a nice hard shell but it can still be scrached like a real paint job on a car. dipli-color for tose that dont know is made by dupont. you know the guys that make just about every paint that body shops use.
Old 10-31-2003, 05:23 AM
ok cool cool, i'll pick some up tommorrow prolly and give 'er a nice clear coat finish, so it won't be so dang tacky....thanks alot
Old 10-31-2003, 06:09 AM
Oh yeah, I forgot that...nice catch guys. The clear coat should help out. I used Dupli Color Automotive sprays on my Zips before I started using Tamiya. If there was no more Tamiya, that would be my brand of choice.
Old 10-31-2003, 06:34 AM
viperkilla's Avatar
Re: testors paint....
I have to agree with you there, testors does take some time to dry. But not 3 days. Maybe you are laying the coats on too thick.
Old 10-31-2003, 10:23 AM
badsupra1239 badsupra1239 is offline
i did not have any problems with it at all
Old 10-31-2003, 12:40 PM
dragon4450's Avatar
customanix
i sware they need to start paying you for all these ads
i like the tamiya paints also cos you get a better color choice.
Old 10-31-2003, 12:48 PM
neurokinetik's Avatar
My RSX paint felt "soft" even after a week. I think it's a characteristic of the enamel type paints. As someone else pointed out, The Testors paint tends to be thick. If you were airbrushing, you'd thin it before spraying it, ut if you are using a spray can, obviously that option is out the window. I think the method of placing the can in a glass of warm water before you spray is a good idea, and might help a bit here.
Old 10-31-2003, 01:18 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
warming up the can should simply increase the pressure inside, very useful when teh can is running low
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 10-31-2003, 02:54 PM
mbartell mbartell is offline
so I re-wired it
Testors paint is a little soft. I always try to put it on really really thin- like mist a cloud over the bodyfrom 2 feet away. Keep doing this untill it gets a solid coat.
Painting is a lot of technique, kind of hard for me to explain. I've just been doing it for years.
before you put diffrent brands of spray paint n top of each other, make a test peice- like a spare spoiler, a chunk of packaging or whatever, and make sure the paints are compatable. Diffrent brands have diffrent chemicals in them, and some attack each other. You don't want to spend days (or months) preparing a custom body, and ruin it after 10 layers of paint by putting on the wrong clear.
Also, you don't want a primer that won't hold your paint, and will let the color coat peel straight off.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Member's collection of painting tips. suprafreak33 XMODS Mods and Projects 26 04-26-2007 04:15 PM
problem with testors paint scatmanjohn01 XMODS Mods and Projects 2 12-30-2003 06:43 PM
What do i need to paint my Xmod ron6 XMODS 11 10-27-2003 11:39 PM
How to Paint Lexan Bodys headhunter555 ZipZaps 14 02-26-2003 05:35 PM
Paint Jobs For Sale/trade! Superimport2nr For Sale/Trade 12 01-25-2003 10:31 PM
