Old 10-28-2003, 10:14 PM
seiyoun seiyoun is offline
that would be hard...but doable.
hmmmmm i wanna try that now...
Old 10-29-2003, 08:57 AM
ron6 ron6 is offline
BC can you show where you add the extra lights on the pc bord and show what part to souder them on.
Thanks
Old 10-29-2003, 11:10 AM
Bad Company's Avatar
Thanks
You just splice the new lights in with the existing ones on your current lights kit...
You get three light kits, and remove the headlights from the 2 extras, and one of the tail light sets. Next you just splice the wires for 3 headlights together. Be sure to splice the wires with the white line to each other, and the ones without it to each other. Do this for both sides. Next do the same with the 2 tail lights on each side.
You should end up with a mess like this...
Old 10-29-2003, 11:13 AM
Right now, I just have them taped in, because I have to pull them out to paint the body, but I will hot glue them in once I'm done.
Old 10-29-2003, 11:27 AM
TwizteD TwizteD is offline
Send a message via AIM to TwizteD Send a message via Yahoo to TwizteD
was that hard 2 wire up??
Old 10-29-2003, 07:46 PM
oOfrog_BoyOo oOfrog_BoyOo is offline
Poopie monster
Send a message via AIM to oOfrog_BoyOo
HOLY CRAP
wat
Old 10-29-2003, 07:50 PM
No not really, it's just a matter of splicing the same wires together from 2 or 3 light kits. The next time I do one, I will put together a tutorial with pics (if someone else doesn't first....hint..hint).
Old 10-30-2003, 12:22 PM
BC how did you make the extra holes in the back and front for the lights and can you also tell me how to take of the plastic peaces for the lights so it will be easier for me to paint my skyline with out getting paint on it and can you show me your set up when you paint your rsx and what color primer should i use if im trying to paint my car matalic navy blue.
thanks
Old 10-30-2003, 12:33 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
you'll probably need to drill the holes yourself. for the clear plastic pieces, take a hobby knife and take out the excess plastic. i believe the factory partially melts the plastic to hold it in.
i too did this mod to my red supra, but not 6 headlights, i have only 4 headlights, shoved the 2nd set of lights into the space where the clear plastic piece in the stock bumper is. i'm thinking of splicing in yellow lights so i get two white headlights up top and yellow foglights below.
for soem screwy reason, my taillights stopped working. not sure if it's the light kit's wiring or the wiring in my car
*edit*
btw, anyone else's lights kinda flicker when idling?
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 10-30-2003, 01:31 PM
yeah i think they all flicker a little bit
Old 10-30-2003, 02:12 PM
Some of mine flicker too. For the extra holes, I used a hand drill (like an x-acto blade, but with changeable bits) to drill out the holes the same diameter as the LED's. Like TypeZer0 said, I used a Dremel to remove the excess plastic (or glue) on the inside, and used a screwdriver tip to push the lenses out from the inside.
Old 10-30-2003, 03:29 PM
viperkilla's Avatar
Re: Re: nice!!!
Originally posted by Bad Company
Yeah, this thing could take out a city's entire electrical grid.
LOL...I am going to try that on my skyline.
Old 10-30-2003, 06:50 PM
Nii Nii is offline
Is there any space to but some leds like underneath your car but above the skid Plate?
And when your put the extra lights on do u have to soder the wires to the mother that the command logic lights came with.
Howmuch do extra leds cost
Old 10-30-2003, 07:01 PM
Nii Nii is offline
Old 10-30-2003, 07:02 PM
No soldering. You just cut the wires going out to the LED's in half, and splice them with the new LED's. Just twist them together and wrap with electrical tape. You could shrink wrap them if you want to get fancy. The Light Kits are $5.99.
to any1 that has done the ultimate light mod or is good in electronic Weapon-NZ Bit Char-G Mods and Projects 14 07-02-2003 06:07 PM
a diffrent light mod GothSkyline Bit Char-G Mods and Projects 2 12-29-2002 11:06 PM
Super light mod gek Bit Char-G Mods and Projects 17 11-17-2002 08:03 AM
Beginner and Ultimate Light Mod DigitalAce7 Bit Char-G Mods and Projects 4 11-12-2002 11:45 AM
fIbEr OpTiC lIgHt mOd...?? JojoPB Bit Char-G Mods and Projects 2 10-18-2002 06:54 AM
