10-27-2003, 09:53 PM
We NEED bodies
My paintjob just got messed up royally. I would like to get another body instead of going through all the work of paint removal. Also if we crack a body up we are basically outta luck......not good........ Anyone know any replacements, possibly lexan or whatever that will fit? Or do any of you know how to get FUBARED paint off of plastic?
10-28-2003, 09:33 AM
so I re-wired it
Old modeler's tricks here-
To take the paint off of plastic, dip it in brake fluid.
Like car brake fluid, $1.29 at most auto parts stores, and probably .99 at Walmart.
Get a small tub (rubbermaid that you will not use for anything else again ever), pour the fluid over your body and let it sit. Check on it and make sure the surface is wet with brake fluid. After a while (depending on the quality and thickness of paint) it will wrinkle up and slide off. Use a stiff toothbrush to get it out of your lines and mouldings.
This will remove paint all the way to the plastic, and usually not damage anything plastic.
Once the car is clean of paint, wash it with dish soap and water.
You should be back down to the original plastic.
Anyone notice that the rims on the RSX are clear under the paint? Might be just mine.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
10-28-2003, 09:39 AM
I think and am hoping that after Xmas you will see new bodys stocking the shelfs. They want to get as many people as they can to buy the 50 $ cars as they can just to get the other bodys then they should release it at least thats my opinion.
10-28-2003, 12:08 PM
customanix
actualy it seems to be that way with all of them not just the rsx. i got the rim set and they did a crappy job of painting them and the back halvs of the rims are clear.
10-28-2003, 01:46 PM
a guy at my radioshack said that they will be getting just bodies in, although he doesn't know when. like a prior post said, it'll probably be after everyone has bought a starter kit
10-28-2003, 02:50 PM
Same here. I called my radioshack and they said that they will be getting some bodies later on.
10-28-2003, 08:34 PM
hey
I have used some model car bodies on mine...just make the mounts out of sheet plastic (available at hobby stores) just try to find a body that is close to the same wheelbase...then just trim it to fit correctly...
10-28-2003, 08:39 PM
revel model bodies work...
rs wants to sell you bodies as bad as u wanna buy em trust me. that will come when they can get around to it. the team has more than just xmods to work on ya kno...
I am the insider, i kno all
10-29-2003, 08:04 PM
here's one
this is my mini z (same exact dimensions as the xmod) and it has a revell acura model car body on it...all I did was use soem mounts out of an old body on it...I made the ground effects out of scrap lexan and covered it with carbon fiber sticker material from the local hobbyshop...and added a fake intercooler and tailpipe from another model car...the brake disks are from a 1:18 diecast motorcycle...just enlarge the hole in the center and glue into your wheel...
10-29-2003, 08:09 PM
wow nice teg!!! i love the intercooler
how did you make that or what car did it come off of?
10-29-2003, 08:15 PM
my brother has a red integ model in his closet and im tempet to gut it and put it on my xmods but he is at college and he'll be coming back soon and he'd kill me so I think i might go out and buy one.
but daaaayyuuumm thats a nice teg
10-29-2003, 08:28 PM
thanks...
it's a Revell plastic model car body...got it at the hobbyshop...
