Old 10-22-2003, 10:49 AM
cj1267's Avatar
cj1267 cj1267 is offline
CJ's Hobbies.net
Send a message via ICQ to cj1267 Send a message via Yahoo to cj1267
Post CJ's Xmods FAQ (updated June 27th)
CJ's Xmods FAQ from CJ's Hobbies.net
This FAQ is for current and future XMODS owners. Please help keep this updated by visiting the CJ's Hobbies.
#1 They are 1:28 th scale and about 6" long.
#2 Known RS part numbers and prices.
Cat # Description Price
60-8001 Nissan Skyline Starter Kit $49.99
60-8002 Acura RSX Starter Kit $49.99
60-8003 Black Honda Civic Starter kit $49.99
60-8004 Blue Honda Civic Starter Kit $49.99
60-8005 White Toyota Supra Starter Kit $49.99 Retired
60-8006 Red Toyota Supra Starter Kit $49.99
60-8008 Black 1999 Nissan Skyline Starter Kit $49.99
60-8501 Stage 1 Motor Upgrade kit 26,000 RPM $12.99 Retired
60-8502 Stage 2 Motor Upgrade kit 30,000 RPM $15.99
60-8503 Foam Tire and Wheel Upgrade $7.99
60-8504 Tire Upgrade $7.99
60-8505 Suspension & Steering Upgrade $7.99
60-8506 All Wheel Drive Upgrade $14.99
60-8507 Racing Crystal Set $19.99
60-8508 Wheel Upgrade $9.99
60-8509 Lighting Kit $5.99
60-8511 Graphics and Decal Set $5.99
60-8512 Metal Ball Bearing Upgrade $19.99
60-8513 Black Honda Civic Body kit $12.99
60-8514 Blue Honda Civic Body Kit $12.99
60-8515 Acura Body Kit $12.99
60-8516 Nissan Skyline Body Kit $12.99
60-8517 White Toyota Supra Body Kit $12.99 Retired
60-8518 Red Toyota Supra Body Kit $12.99
60-8519 Tool Kit $12.99
60-8520 Carrying Bag $29.99
60-8522 Medium Xmods T-Shirt $14.99
60-8523 Orange Nissan 350Z Body Kit $12.99
60-8524 XL Xmods T-Shirt $14.99
60-8527 Large Xmods T-Shirt $14.99
60-8541 XXL Xmods T-Shirt $14.99
60-8542 Xmods Hat $9.99
60-8543 Xmods Keychain $4.99
23-350 Xmods Battery Charger $24.99
990-0458 18-Piece Narrow Oval Racing Track Set $129.99
Includes 18 bottom tiles, 18 side rails and a complete set of pins.
Completed track is an oval approximately 10 feet long and 5 feet wide.
Features two surface textures–low grip and high grip.
990-0459 28-Piece Wide Oval Racing Track Set $159.99
Includes 28 bottom tiles, 28 side rails and a complete set of pins.
Completed track is an oval approximately 11 feet long and 6 feet wide.
990-0460 40-Piece Wide "L" Turn Racing Track Set $199.99
Includes 40 bottom tiles, 40 side rails and a complete set of pins.
Completed track is an “L” shape approximately 13 feet long and 10 feet wide.
Modular design allows you to combine multiple starter track sets together to create larger and more spectacular layouts
Some special order parts my even be a lap counter and transponders.
#3 Xmods Bearings:
Xmod Bearings are unflanged and unsealed. Measurements are .235" Outside Diameter x .115" Inside Diameter x .079 Thick. In mm it is 3mm ID x 6mm OD x 2mm Thick. Have been told some Mini-Z bearings will fit. Note 3mm x 6mm x 2.5mm will fit in most places and reduce play and improve performance.
#4 Axles/Drive Shaft:
Axles are also .115" in diameter or 3mm.
Long Drive shaft 2.97 X 81L
Medium Drive Shaft 2.97 X 77L
Short (if there is one) 2.97 X 73L
#5 Remote:
The Xmods remotes that come with the cars are the ONE AND ONLY remotes that will ever work with the cars unless you replace the electronics inside (Receiver/Speed Control/Servo/Controller). Xmods Controllers with the same crystal WILL control other Xmods with the same Crystals.
#6 Manuals:
XMODS 1999 Nissan Skyline GT-R VSpec Starter Kit
XMODS 2003 Acura RSX Starter Kit
XMODS 2000 Honda Civic Coupe (Black) Starter Kit
XMODS 2000 Honda Civic Coupe (Blue) Starter Kit
XMODS 1997 Toyota Supra (White) Starter Kit
XMODS 1997 Toyota Supra (Red) Starter Kit
XMODS Custom RC Stage 1 Motor Upgrade Kit
XMODS Custom RC Rubber Tire Upgrade Kit
XMODS Custom RC Steering and Suspension Upgrade Kit
XMODS Custom RC All Wheel Drive Kit
XMODS Custom RC Racing Crystals Set
XMODS Custom RC Wheel Upgrade Kit
XMODS Custom RC Command Logic Lights Kit
XMODS Custom RC Metal Bearing Upgrade Kit
#7 Wheel Nuts:
Wheel nuts are 2mm. Stock nuts are plastic. Most 2mm Lock Nuts should work. 2mm Lock nuts are used on the Mini-Z and the RS4.
#8 Mini-Z parts:
Bodies: Will NOT fit with out modification to the body mounts. Not all Mini-z bodies wheel basses are the same. So you may need to stretch or shorten the chassis on a Xmod. Changing the chassis length will also require changing of the drive shaft.
Battery Clips: On the Original Mini-z the clips can fit with minor sanding or fileing. The MR-02 is a new design and not at all compatible.
Motors: Mini-z motors will physically fit in the Xmod but the stock electronics may not be able to handle the faster more powerful motors. Also you will need to invest in a Pinion puller from a hobby shop that sells the 1:24 scale slot cars to remove the brass pinion on the Xmods motor. Don't forget your soldering iron as well.
Tires: The rubber tires on the Mini-Z can fit but since the Xmods have a raised part in the center of the wheel they will have a raised center when installed.
Part 2 listed further down
CJ's Xmods FAQ with Photos of parts
Old 10-22-2003, 12:08 PM
Namuna's Avatar
Namuna Namuna is offline
Originally posted by cj1267
BTW can Namuna or BC can sticky this PLEASE
Most deservedly so.
Old 10-22-2003, 12:55 PM
Bad Company's Avatar
Nice work CJ. You have always kept us well informed.
Old 10-22-2003, 03:45 PM
viperkilla's Avatar
Hey CJ I was wondering if you know when we will see the tool kits and the carrying case. Is the carrying case like a back pack?
Old 10-22-2003, 04:38 PM
Savior*insider Savior*insider is offline
messenger bag.
hey cj! a fellow pimp!
I am the insider, i kno all
Old 10-24-2003, 07:28 PM
viperkilla's Avatar
What does the 60-8511 Graphics and Decal Set look like and how much is it? There wasnt a price listed.
Old 10-27-2003, 12:11 PM
cj1267's Avatar
CJ's Hobbies.net
XmodsRC FAQ part 2 (Updated May 25th)
XmodsRC FAQ Part 2
#9 RadioShack Parts:
Common
RSU# Description Sug. Retail
12414272 - ANTENNA RX $2.49
12414413 - ANTENNA TX $4.69
12414280 - COVER BATTERY RX $2.49
12414298 - LEFT BATTERY CASE ASSY RX $2.49
12414306 - RIGHT BATTERY CASE ASSY RX $2.49
12414470 - BEARING $2.49
12414199 - HARDWARE KIT 64 PCS $2.69
-SCREW TAPPING 2.0 X 3.3 CB 8 PCS
-SCREW TAPPING 2.0 X 8 CB 5 PCS
-SCREW TAPPING 2.0 X 9 PCM 8PCS
-SCREW TAPPING 2.0 X 5 PB 7 PCS
-SCREW TAPPING 2.0 X 10 KB 2 PCS
-SCREW TAPPING 2.0 X 6 KB 11 PCS
-SCREW TAPPING 2.0 X 10 KB 4 PCS
-SCREW TAPPING 2.0 X 5 KB 6 PCS
-SCREW TAPPING 2.0 X 8 KB 2 PCS
-SCREW TAPPING 2.0 X 6 PWB 1 PCS
-SCREW TAPPING 2.0 X 12 PB 2 PCS
-LUG NUT 8 PCS
12414215 - SERVO ASSY $8.69
12414421 - MANUAL USERS 60-8001 $2.49
12414231 - HOLDER CENTER SHAFT (FRONT) $2.49
12414249 - HOLDER CENTER SHAFT (REAR) $2.49
12414314 - JOINT CUP CENTER SHAFT $2.49
12414322 - JOINT CUP CENTER LEFT $2.49
12414348 - DIFFERENTIAL SHAFT 1.0 X 11 $2.49
12414355 - DIFFERENTIAL GEAR SET $2.49
12414363 - ARM LEFT REAR $2.49
12414371 - ARM RIGHT REAR $2.49
12414181 - AXEL SHAFT REAR (1) $2.49
12414389 - KNUCKLE FRONT LEFT $2.49
12414397 - KNUCKLE FRONT RIGHT $2.49
12414405 - AXEL SHAFT FRONT (1) $2.49
12414462 - GEAR DRIVE 2A $2.49
12414207 - PCB ASSY RECEIVER $9.49
12414223 - CHASSIS $2.49
12414256 - DECK UPPER FRONT $2.49
12414264 - DECK UPPER REAR $2.49
12414488 - DAMPER ASSY (4) $2.49
NOTE: RS may have this listed as a DUMPER ASSY or a BUMPER ASSY
:60-8001XMODS NISSAN
12414454 - CRYSTAL BAND 1 (26.540MHZ) RX $2.49
12414512 - CRYSTAL BAND 1 (26.995MHZ) TX $2.49
12414447 - SHAFT CENTER 2.97 X 81L $2.49
12414496 - CAR BODY ASSY $7.69
12415691 - MIRROR SET NISSAN SKYLINE YEL $2.49
12414504 - TRANSMITTER KIT $14.89
:60-8002 XMODS ACURA SILVER
12414520 - CRYSTAL BAND 2 (26.590MHZ) RX $2.49
12414553 - CRYSTAL BAND 2 (27.045MHZ) TX $2.49
12414439 - SHAFT CENTER 2.97 X77L $2.49
12414538 - CAR BODY ASSY W/ACURA SILVER $7.69
12415683 - MIRROR SET ACURA RSX SILVER $2.49
12414546 - TRANSMITTER KIT $7.69
:60-8003 XMODS HONDA CIVIC BLACK
12414561 - CRYSTAL BAND 3 (26.640MHZ) RX $2.49
12414595 - CRYSTAL BAND 3 (27.095MHZ) TX $2.49
12414579 - CAR BODY ASSY $7.69
12415709 - MIRROR SET CIVIC BLACK $2.49
12414587 - TRANSMITTER KIT $7.69
:60-8004 XMODS HONDA CIVIC BLUE
12414603 - CRYSTAL BAND 4 (26.690MHZ) RX $2.49
12414637 - CRYSTAL BAND 4 (27.145MHZ) TX $2.49
12414611 - CAR BODY ASSY $7.69
12415816 - MIRROR SET CIVIC BLUE $2.49
12414629 - TRANSMITTER KIT $7.69
:60-8005 XMODS WHITE TOYOTA SUPRA
12414645 - CRYSTAL BAND 5 (26.740MHZ) RX $2.49
12414678 - CRYSTAL BAND 5 (27.195MHZ) TX $2.49
12414652 - CAR BODY ASSY $7.69
12415824 - MIRROR SET SUPRA WHITE $2.49
12416723 - FRNT ATTACHMENT TOYOTA SUPRA $2.49
12414660 - TRANSMITTER KIT $7.69
:60-8006 XMODS RED TOYOTA SUPRA
12414686 - CRYSTAL BAND 6 (26.800MHZ) RX $2.49
12414710 - CRYSTAL BAND 6 (27.255MHZ) TX $2.49
12414694 - CAR BODY ASSY $7.69
12415832 - MIRROR SET SUPRA RED $2.49
12414702 - TRANSMITTER KIT $7.69
To use a replacement body that is not original to your chassis you MUST also replace the front mount which so far has not yet become available. Update part #12416723 may be this part for the Toyota Supra.
For RSU you must also add shipping. Under $9.99 add $2.50.
You can order parts by visiting the store or calling the Shack at 1-800-THE-SHACk.
#10 Motors: (thanks to neurokinetik at tinyrc.com)
Stage 1: 85 turns, wire thickness is less than 30 gauge. Probably 32 or 34.
Stage 2: 49 turns, 30 gauge.
X Speed: 49 turns, 30 gauge.
Crest Spin Brush: 70 turn of ~ 32 gauge
#11 After Market Parts: Not made by RadioShack Use of these parts could void your warranty!
Tinyrc.com - Decals and carbon fiber Drive shafts - see website for prices - http://www.tinyrc.com/
wjhecox@yahoo.com - Aluminum Drive Axles - Ask him for price -
http://www.geocities.com/wjhecox/photopage.html
slugbugg@ameritech.net - Carbon Fiber Drive Shafts - $10 a Set
If you make any aftermarket parts that are not listed or want to update a part that is listed email cj@cjshobbies.net
Aftermarket parts listed must not be exclusive to Ebay.
Old 10-27-2003, 12:22 PM
BTW: Namuna How can I add "(updated Oct 27th)" to the Subject so it apears in the fourm?
Hope you don't mind, I took care of that for ya CJ. btw, More very usefull info, as always. Thanks!
Old 10-27-2003, 06:42 PM
Btman Btman is offline
Very good job providing links to the manuals of the starter kits and upgrades!
Old 10-27-2003, 08:38 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
hey guys, can you give me specs (like speed , turning radius, dimensions, ect.) for an xmod? Any info would be much appriciated!! i hope to buy one soon but i want to know specs.
--Chris
Aka...aero528
Old 10-30-2003, 04:26 PM
aero528's Avatar
like my dog??
Cool
some of you that have an xmod can you give me specs PLEASE!!!!!!!!!!!!!!!!!!!!!!?????????????
--Chris
Aka...aero528
Old 11-04-2003, 12:35 PM
neurokinetik's Avatar
# 5 is actually not true, at least not for cars of the same type. We had a guy running two white Supras off the same remote at the same time last night. It was pretty funny... synchronized driving. :lol:
Old 11-05-2003, 01:41 PM
HPIracer HPIracer is offline
Send a message via AIM to HPIracer
I believe he means that you can only use xmods controler. You wont be able to say put the xmods crystals in a mini z controler and use that. You should be able to use any xmod controler though as long as its on the same freq.
Old 11-13-2003, 07:33 PM
cj1267's Avatar
CJ's Hobbies.net
Updated
RadioShack is now listing parts for the Xmods. All parts are special order. Please do not reply to this.
Old 11-23-2003, 03:28 AM
_revhards13 _revhards13 is offline
I think thier cute!
Send a message via AIM to _revhards13
ok, so i need the white supra body, all i have to do is call up and ask for the part number? please let me know how it works, and dont get on my ass for replying its a very intriuging post... i desparatly need spare parts!
Xmods Spoilers cj1267 XMODS 75 10-17-2003 11:00 AM
Xmods Announcement cj1267 XMODS 2 10-16-2003 05:34 PM
