Old 10-24-2003, 10:35 AM
mbartell mbartell is offline
so I re-wired it
Something I learned in architectural model building- make a test peice out of a cheaper material- like a cerial box- and use it for a template before you start cutting.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 10-24-2003, 10:58 AM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
Yeah I kind of do that but I just draw the part up then print it to scale and check it, If I have to I can even cut and fold the piece.
There is a lot more to it that the paper model will not show, but for this chassis I'm going straight to the fiberglass when I feel it's ready since I dont have aluminum the same thickness as the fiberglass sheet(parma chassis material).
I'm already planning on just cutting the main chassis piece first then follow up after with the front/rear top plates.
I used to cut pieces by drawing them up and fitting them then print it out on a full sheet of label paper and stick it to the aluminum sheet and drill/cut/file.It worked good and I could duplicate parts easy.(hmmm- I dont do that now)
Old 10-24-2003, 10:01 PM
atomikplayboy atomikplayboy is offline
Originally posted by Savior*insider
yes there will be team racing. there are plans for every team to have a "garage" on the xmods website where u can go and put pics of ur cars and a calendar of races and other team related things. there will be a member login on the website that launches 10/24/03.
The XMODS site is no different today... unless you were talking about another site...
AP
Old 10-24-2003, 10:21 PM
Savior*insider Savior*insider is offline
... yes i kno the website update has been delayed. it was scheduled for today, not sure how far back they moved it.
I am the insider, i kno all
North & South Carolina Modders Section Char-g Ace Bit Char-G / MicroSizers 19 07-17-2003 01:50 PM
eastern USA modders section Char-g Ace Bit Char-G / MicroSizers 58 07-15-2003 06:09 PM
East Coast Modders MicRoMaN Bit Char-G / MicroSizers 33 03-09-2003 05:25 PM
US Modders MicRoMaN Bit Char-G / MicroSizers 19 03-02-2003 10:25 PM
Any word on new body styles? Vincent Bit Char-G / MicroSizers 1 11-28-2002 12:09 AM
