Old 10-22-2003, 03:53 PM
NOS man's Avatar
NOS man NOS man is offline
SHYMERLOO!!!!
Send a message via AIM to NOS man
i need help.... big problem!!!!!!!!!!!!
ok...new batteries in controller and car, motor works fine, fron wheels realign when the car is turned on, nothing happens when i turn on the controller and pull the trigger. the car dont move and the steering doesnt work at all.....WHATS WRONG????????????????????????????????????????!!!!! !!!!?1?1?!?
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
Old 10-22-2003, 03:56 PM
Silent_NightR34's Avatar
Got Mini-z?
try taking out the crystals and reinstalling them...
Old 10-22-2003, 04:06 PM
NOS man's Avatar
SHYMERLOO!!!!
i tried it... IT DOESNT WORK!!!!!!!!!!!!
I cant return it because im runnin a stage 2 moter(blue) AWD metal bearing upgrades, light set, suspension upgrade, and nimh rechargable battery upgrade. i dunno whats wrong??? any more ideas?
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
Old 10-22-2003, 04:10 PM
Make sure you didn't accidentally tear the antenna wire off. Make sure it's still soldered on to the silver thing that you screw in.
Old 10-22-2003, 04:45 PM
metsrule119's Avatar
metsrule119 metsrule119 is offline
Actually, they suck^
Send a message via AIM to metsrule119
I had a similar problem-
the problem was that the battery in the transmittier wasnt making full contact wiht the contacts. What i did was I took a piece of masking tape and rolled it up and put it in the battery compartment to make the battery fit more snugly. Let me know if this works.
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Toy East Mini Cooper
1 Precious Clone
Old 10-22-2003, 04:46 PM
NOS man's Avatar
SHYMERLOO!!!!
it is soldered on....
what else could be wrong?
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
Old 10-22-2003, 04:48 PM
NOS man's Avatar
SHYMERLOO!!!!
the battery is snug.
i tried the masking tape thing. it doesnt work....
DAMMIT!!!!!!!!!!
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
Old 10-22-2003, 06:23 PM
crusader4x crusader4x is offline
Sounds like it's time for you to remove your mods, put the stock parts back in, and return it to your Rat Shack.
Old 06-28-2006, 02:19 PM
bengali548's Avatar
bengali548 bengali548 is offline
(insert something funny)
i have the same problem i think reverse and see if that works
Old 06-28-2006, 04:08 PM
iphong iphong is offline
You should check if any wires touch the atenna, it would shorten the range, and if you leave it like that for long time, you would fry the range inductors. In this case, you have to buy a new range repair kit.
Hope this help.
Old 06-28-2006, 04:16 PM
bengali548's Avatar
do you know anything about my prob my range isnt messed up just the accelerate
Old 06-28-2006, 09:21 PM
Jazz32
I've sometimes noticed that they connections that the crystals slide into stop making contact. Try to pry them in a little to make a tighter connection to the crystals. Also, do you have multiple crystals of the same label? The reason I ask is because I have a lot of crystals, and some of the ones labeled the same still will not work together, i.e. some of my label 3 crystals will only work with certain other label 3's.
Does the power light turn on your remote when you turn it on? If you touch the remote antenna to the car, will it work then? If it's not those, then it's not a power problem. When did it last work and what changed since then? These are the questions you need to ask yourself. Isolate all the variables you can and test them. It helps us out a lot too if you can tell us what you have tried and give more details about the problem.
Old 06-28-2006, 10:53 PM
bengali548's Avatar
alright it worked perfectly until the wires that were conected to another battery touched the motor the motor spun really slow (because only one battery was running it) and when i removed the wires the accelerate stopped working crystal worked fine did everything else dunno wuts happenin
big stupid problem!!!!!! GerG ZipZaps 12 03-12-2004 12:31 AM
yo ahh5hit BIG PROBLEM spazzykid123 ZipZaps 3 07-01-2003 02:34 PM
Please Help Big Problem! MBHockey ZipZaps 15 05-06-2003 11:25 AM
got i really big problem, need help asap danny_v_l Bit Char-G / MicroSizers 1 04-27-2003 08:34 PM
Big Problem was ist los? ABC DTM Electronics 2 09-06-2002 08:15 PM
