Old 10-20-2003, 09:59 PM
NOS man's Avatar
NOS man NOS man is offline
SHYMERLOO!!!!
Send a message via AIM to NOS man
my x mod stutters....
when i pull the trigger, the x mod stutters. it accelerates then stops like every .5 seconds yes i did say .5. whats the problem?
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
Old 10-20-2003, 10:09 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Dead controller battery.
Old 10-20-2003, 10:30 PM
Btman Btman is offline
Just purchased an XMODS today and I like it a lot. The transmitter did not turn on at all at first so I thought I had a bad battery. I checked it with a volt meter and it was somewhat low. Then I compared it to the Radio Shack 9V battery I happened to buy while buying my XMODS and noticed it was about 1/8" shorter than the Radio Shack battery! The point is that all brands of 9V batteries are not the same height. This means that the battery may not be making a good connection in the transmitter. Your batteries in the car may be getting low as well. I had a similar experience, checked the voltage on my rechargeable batteries, and they were low.
Old 10-20-2003, 10:34 PM
dEmOnRaCeR's Avatar
"Its OK I had subway"
same thing happeded to me but it was cause i had the wrong gear with my motor unless it was the battery
Old 10-21-2003, 12:42 PM
NOS man's Avatar
SHYMERLOO!!!!
i just charged the aaa batteries and put em in the car.
when i remove the motor from the car and pull the trigger, the motor doesnt stutter. only when it has contact with the gears...
i have a new 9v in the controller...
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
Old 10-21-2003, 01:02 PM
I have a beach ball...
The question is not wether or not it's a new 9v, the question is is it making good contact? Is it a radio shack 9v or some other brand?
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 10-21-2003, 01:27 PM
viperkilla's Avatar
Well it seems that everyone has an XMOD except for me! Oh well I should be getting an RSX this Thursday hopefully.
Old 10-21-2003, 03:42 PM
If you have access to a digital voltmeter, check both the transmitter and car battery voltage. A new 9 volt battery should read 9 volts or more and fully charged batteries should read about 1.4 volts or more each. If you dont have a voltmeter, try another set of batteries in the car. You could buy a cheap set of disposable alkalines to try this. I have purchased batteries several times in the past where the polarity of the battery (+ and -) was backwards. I doubt that this is your problem but it is possible. The first thing is to make sure the battery in the transmitter is making a good connection as well as the batteries in the car. Also make sure that you rear wheels spin freely. If there is something either in between the wheel or between the gears it may be causing it to bind.
Best Mod Contest (UNOFFICIAL) midget_man1387 Bit Char-G Mods and Projects 56 03-17-2003 10:38 PM
