10-20-2003, 01:24 PM
XMOD bodys
are the xmod bodys interchangable? or do they only fit to the car the came with. is the car body size diffrent or is every thing built from the same main car but adjustible for the diffrent bodys?
10-20-2003, 03:51 PM
Ummm....I am not positive with this answer but I am assuming that the bodies are interchangable.
10-20-2003, 03:53 PM
Got 4.2 King? I do : )
on the front tab, all the chassies are different. the body only fits a certain one. also i heard that the rsx is a bit shorter than the supra and skyline
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
10-20-2003, 03:58 PM
its possible the civic and rsx are inter changeable and the supra and skyline are interchangeable but thats about it
10-20-2003, 04:02 PM
i have the skyline and my brother has the supra. inorder to swap the bodies you would have to swap tabs. the supra tab is much wider than the skyline tab
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
10-20-2003, 04:04 PM
OH AIGHT... i dint know, im not rich enough to buy more than one right now
10-20-2003, 04:36 PM
I KNOW NOTHING!!!
Actually if you look very close to the tab on the bottom it will say what car it belongs to.
My supra uses the farthest wheelbase hole and my RSX uses the middle wheelbase hole.
10-20-2003, 06:08 PM
I see why they did it BUT that sucks... Seems like it'll make it difficult for them to make additional bodys for these things.
AP
10-20-2003, 06:13 PM
no it should be real easy, every car would just come with a tab. but it might be harder to get shorter bodys on longer cars
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
10-20-2003, 06:24 PM
You would have to remove the front springs to change out the front tab. If you are swapping different wheelbase bodies, then you will have to change the wheelbase on the chassis, which is a matter of loosening the two screws on the bottom. I have yet to try this, but I'm thinking you may have to swap out the driveshafts too?
10-20-2003, 06:33 PM
yeah i tried this the drive shaft is a diffrent length for each setting so u would have to change it for a diffrent body
