Old 10-08-2003, 10:06 AM
zzmaniac zzmaniac is offline
Bodies cracking
Has anyone had trouble with the older bodies cracking when you put it on the se chasis? I have had the civic body and 2 blue camaros to crack below the tab hole.
Old 10-08-2003, 03:29 PM
I have a beach ball...
I haven't put any older bodies on it yet, but my savanna body is cracked right below the rear slot. I'm slightly angered by this *twitches eye*
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 10-08-2003, 03:36 PM
Bad Company's Avatar
I haven't had any crack yet, but some are pretty tight when trying to put them on, and it's only a matter of time if you keep changing them out. I have noticed that almost all bodies including the SE's are really tight on the sides and have to be spread out to get them over the chassis.
Old 10-08-2003, 11:45 PM
tobenjunk tobenjunk is offline
savannah crack :(
mine fell off table mountain and the plastic below the tab broke off, i just put some superglue on it to hold it... maybe I can sand it down so it's not as messy and then paint my car another color. :]
Old 10-09-2003, 07:25 AM
I know that alot of them are tight going on. I wonder if it is where they redisgned the front of the se. It has alot of give in the front. It also seems like the bodie slot are a little more narrow on regular zips.
Old 10-09-2003, 07:22 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
all of my old and new bodies are tight on the sides and i have to put one side on at a time to spread them out. do not spray these bodies with a can of pressurized air while it is inverted! it will freeze the body and crack it!
(i learned the hard way)
NEVER UNDERESTIMATE THE POWER
Old 10-10-2003, 09:38 AM
MadeInUSA MadeInUSA is offline
Send a message via AIM to MadeInUSA
I know my yellow rx7 SE is cracking where the clips lock to the chasis. That could be from me hitting walls though LOL.
Old 10-10-2003, 10:27 AM
I have cracked them by hitting stuff to, but I'm talking about just putting the body on the chassis and it cracking at the tab.
Old 10-11-2003, 12:41 AM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
I have had several bodies crack below the rear tab too. I was thinking of cutting away a little of the plastic that the body rests against there where the motor screw goes.
That's all folks!
Old 10-11-2003, 06:35 AM
viperkilla's Avatar
When my bodies break then I just super glue the pieces together. That seems to work well.
Old 10-11-2003, 08:23 PM
bdebde's Avatar
That's all folks
I filed the rounded part under where the screw goes, just enough to make it flat. Looks like that helps reduce the stress there. It no longer pushes out on the bodies that are already cracked, so the crack doesn't show as much. Bodies go on a little easier too. Just don't file too much, may make the wheels not line up in the wheelwells.
That's all folks!
Old 03-20-2004, 03:32 PM
N2O N2O is offline
Im With Stupid -->
hmmm my body above the tab hole has cracked on my subaru,but also i think i must have tightened my screw on the heat sink to tight because on the tab at the back...its cracked so i cant be bothered modding that and ending up broke..Looks like more money down the drain.
Tinyrc.com Rulez!
Looking for some Smart & Puegeot bodies. Blamminator Bit Char-G / MicroSizers 4 02-14-2003 09:35 PM
7 bodies up for trade and a hotwheel kit racer zombiebaby For Sale/Trade 22 02-08-2003 11:03 PM
Epoch spec 2 bodies coming soon!!!!! Epochracer34 Epoch RC1/43 8 02-04-2003 09:15 AM
Looking For These Bodies shanly For Sale/Trade 14 01-29-2003 04:38 PM
D@#& Cracking Bodies and Chassis! johnrtse Bit Char-G / MicroSizers 6 12-15-2002 09:37 PM
