Old 10-05-2003, 05:22 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
ground clearance
anyone else notice that the rear axle mounts a bit higher in the chassis? makes my whole chassis angle up with the front higher than the rear. also, though the front ground clearance is fine, the rear is missing about 1mm or a tiny bit more because i hardly get stuck on my carpet with my old zipzaps but my SE is getting stuck way too easily. i'm guessing they did this to make the gears mesh a little better so it's quieter but they could at least mount the motor and/or idler gear so that it retains the original ground clearance. my SE bodies when mounted are also a bit angled in that the front is a bit higher (liek half a mm) than the rear, making the front noticeably higher than the rear than it should be
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 10-06-2003, 05:44 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
that could be from the new suspension in the se. but i am not quite sure. if you were to take the springs out then the body would probley sit lower in front. if you compress the springs than it is lower in the front.
--Chris
Aka...aero528
Old 10-06-2003, 05:56 PM
TypeZer0's Avatar
0reZepyT
yeah, i kno, but my gripe is the lack of rear ground clearance
Old 10-06-2003, 06:00 PM
aero528's Avatar
like my dog??
k. i dont now get bigger tires or rims. dont now how else you could correct it ill post more if i figure it out.
--Chris
Aka...aero528
Ground Clearance & Drift Rims Tonka XMODS 2 08-23-2006 06:43 PM
Improve Ground Clearance Railside270 XMODS 6 01-05-2004 09:57 AM
Ground Clearence Strider XMODS 7 11-05-2003 03:40 PM
Ground clearance SCX01 XMODS 3 11-01-2003 07:33 PM
super bit char-g? big-key Bit Char-G / MicroSizers 7 08-09-2003 11:26 PM
