Old 10-01-2003, 10:57 PM
newbitowner's Avatar
My axle won't stay put, so the gears slip...
I think I've switched so many axles on this car, so now it doesn't have enough support to hold the axle well enough.
What can I do about this?
Old 10-02-2003, 02:02 AM
boho's Avatar
boho boho is offline
Camera springs
Easy to fix. Take a tooth pick and stick it between the axle and plastic piece that sits under the axle on the bottum of the car. You have to come in from the back. Now just break/cut off the extra piece of tooth pick that you dont need. I put a piece of tape to help hold it down. I wouldn't use glue, because you wont be able to take it off for gear changing. This is something I have to do to dual cells often, because if it's just a little loose with a higher torque, then it will pull to one direction more.
Old 10-02-2003, 06:25 PM
Where does the tooth pick go?
Any pics?
Old 10-02-2003, 06:51 PM
Rex's Avatar
Rex Rex is offline
Bob and Tom Fan
Send a message via Yahoo to Rex
If you have a soldering iron I have a solution. Use it to slightly melt and push the plastic back in to close the gap. I had a Zip Zap come like that and I had to fix it
Good Luck
When in Doubt... Improvise
Old 10-03-2003, 12:04 AM
boho's Avatar
Camera springs
No pics. It's simple though. Just look at the bottum of the bit with the axle on. See where the axle goes in. Now look at it from the back of the car. There is some space between the axle and plastic. Slide a toothpick in there, right in the middle of that space. It's not a round whole you're looking for.
Old 10-03-2003, 08:19 AM
DarkTari's Avatar
DarkTari DarkTari is offline
BitPimp Enforcer
As long as the car in on the floor, it should run fine, it's only when you pick it up that you get the gear slip. Or is it?
DarkTari
If It Don't Fly....."MODIFY"!
Old 10-03-2003, 05:43 PM
micromatch micromatch is offline
Send a message via AIM to micromatch Send a message via Yahoo to micromatch
do a match mod
l< 3 l\l T
Old 10-03-2003, 06:16 PM
I need some toothpicks.
I have a 4.2 motor so it jumps off the gear when the car is on the ground.
Old 10-03-2003, 09:49 PM
I just bought 250 toothpicks from my local Walgreens for $0.99.
I can't get the toothpicks at a position where it hold the axle in place without rubbing againts the actual axle to strong.
In other words, it doesn't move.
Old 10-03-2003, 10:17 PM
Is that what you were trying to tell me to do? Cause it works like new!
Old 10-05-2003, 08:25 PM
eman1 eman1 is offline
custom title
Send a message via AIM to eman1
yes, thats what your supposed to do, when my friend did that it slowed down the car a ton though...
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
Old 10-05-2003, 08:45 PM
we thats cause it to tight!
do what i said and gain speed and fix yur problem...
basically do what you did there but use a peis\ce of a card board match...it will fix your problem and improve performance
l< 3 l\l T
Old 10-05-2003, 09:35 PM
DarkTari's Avatar
BitPimp Enforcer
Hey man, just do what Rex suggested. It's simple and permanent.
DarkTari
Old 10-05-2003, 10:18 PM
boho's Avatar
Camera springs
Yes, the toothpick is positioned correctly. If the wheels aren't turning then move the toothpick back a little (reduce pressure).
DT, you're right when you say that it will run fine on the ground, but it can/will interfere with higher torque. The higher the torque, the more it will pull on one side because the pressure is all on one side and not in the center. It may make one side lift a little. You can correct it with the alignment bar, but it's generally a good idea to keep the alignment bar as close to the center as possible, otherwise it will reduce performance slightly.
I don't want to get too technical about this, but I will explain it like this. You only need upward lift equal to 10% of the car's weight to make the car lift on one side. I've never seen a 1.0 cause this problem, but I've dual celled many cars, and use 2.6~4.2's. With one car, I've changed the back axle so much that there is definately a little extra space. When it runs you can really see it lift slightly on one side, but only during acceleration. So, in other words, after it gets up to full speed, it gos back to normal position. So I can't use the alignment bar to fix the problem because it only pulls during acceleration.
Also, I don't want to disregard what REX has to offer. That is also a good idea.
Old 10-05-2003, 11:47 PM
If I put the toothpick in an angle, it won't slow the car down much.
Great Idea In Saving or Strengthening Your Front Axle Steering Hubs.. MicroRCracer XMODS Parts and Hop-Ups 3 02-09-2004 03:40 PM
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 01:37 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 01:47 PM
new and improved axle holder fix hogjowlz Bit Char-G / MicroSizers 1 03-04-2003 03:24 PM
Axle problem? blind Bit Char-G / MicroSizers 4 08-18-2002 09:03 PM
