Old 09-19-2003, 07:12 PM
newbitowner's Avatar
Can I add more voltage to my R/C?
I got this R/C...
They were made to fit 6 1.5 AA which is 9 volts. Can I add 3 or 6 volts to make it go faster?
http://www.amazon.com/exec/obidos/tg...12665?v=glance
Old 09-19-2003, 07:59 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
That's not a bit/microsizer! The electronics may not handle any more voltage. You may be better off doing a relay mod like they do with Auldeys. If you are not worried about frying it, try 1.5 v more, then 3 v more. I don't think I would risk any more than that though>
That's all folks!
Old 09-19-2003, 08:20 PM
where can i find more about relays? it ran fine with 3v more. I didn't see much of a diff though.
Old 09-19-2003, 10:39 PM
bdebde's Avatar
That's all folks
Check the Auldey Forum here at Tiny RC. Or do a search for Auldey.
That's all folks!
Old 09-19-2003, 10:48 PM
Awaken's Avatar
Awaken Awaken is offline
Feh
Send a message via AIM to Awaken Send a message via Yahoo to Awaken
i got two of those (the first one came not working) i put a connection to the 3 wires for a 9v rechargable battery pack and it works really fast with the 9v battery, sadly i couldnt fit the body on it with it in there because it couldnt fit were the AAs went..so i dunno if you would want to give up looks over performance...but the choise is yours...a little advice...there is two wires that uses positive and one that uses negative...when you put the connection to the 9v...dont put the AAs in because 2 of the batterys get really hot because the two postivies are touching
Give me a moment in which I well never AWAKEN
Old 09-19-2003, 11:24 PM
15V started to burn the wires.
I think I'll stick with 12V.
Have you done the relay mod?
Old 09-19-2003, 11:26 PM
Awaken's Avatar
Feh
i did get to do any other mods because i had the battery fully charged and i accedenty touched its wires on the pcb ad it stoped running so now its a shelf collectable :P
Old 09-20-2003, 12:47 AM
I'm running the car on 18 volts right now. I just had bad contact when I tried to run 2 3V batteries.
here are some pics...
Old 09-20-2003, 02:59 PM
Awaken's Avatar
Feh
nice job man
Old 09-20-2003, 03:41 PM
InGaN's Avatar
InGaN InGaN is offline
GaN: Blue
I have one of those. My brother tried driving it up the slide. Now it doesn't work. I'm guessing it's those things that look like tall transistors, but I have no idea what they are...
< Plane construction paused>
Current Progress: 0%
Old 09-23-2003, 07:13 PM
MaddMatt MaddMatt is offline
Send a message via AIM to MaddMatt
cheaper
Wouldn't it just be cheaper and easier to start changing gears and/or motors?
Usually they have a stock motor and it can be replaced if enough screws are taken out.
Just curious
Madd matt
Matt Walter
Madd Matt's Entertainment
Motor Voltage chelboed Bit Char-G / MicroSizers 4 03-17-2003 10:25 AM
Links to Mini R/C Sites MicRoMaN Bit Char-G / MicroSizers 18 01-13-2003 01:55 PM
R/C battle AnTboTs slotsurfer Other Tiny RCs 5 12-15-2002 03:53 PM
Rechargeable Li-ion adjustable voltage mod actofgod Bit Char-G Mods and Projects 5 12-03-2002 04:34 AM
Using a full size r/c controller? Sniper596 Bit Char-G / MicroSizers 6 11-02-2002 12:09 PM
