Old 09-22-2002, 07:39 PM
asimeman asimeman is offline
Track
Hi folks!
I thinking about building a track. I need infos about that. Do you think a 14 inch (35 cm) wide lane should do it? And the range of the track should be as small as possible. I planned a range of around 7' (feet? 2,3 m) to 10.5' (3,26 m). But I don´t know if this would be enough fun. Has anyone an idea if this is ok for a track to make fun? Or should I make it al little bigger?
Old 09-25-2002, 11:05 AM
tinyrc's Avatar
tinyrc tinyrc is offline
asimeman, that should be plenty for the Epochs. Keep us updated on you track's progress!
Old 10-02-2002, 12:30 PM
Build a Track part#1
Ok!
We have ordered our Epochs and waiting for them. Till they arrive we are planning and building a track. We will make this track of quadrat plates of carpet. These cost 50 cents for one plate (15.76^2 inch). We take 7 plates per row and 5 per column thats 35 plates total (around $17,5) for our track. We already made a drawing of it:
Old 10-02-2002, 12:41 PM
This Track will be 280 cm (110.32 inch ) to 200cm (78.8 inch). the lane is 25 cm (9.85 inch).
we will inform you how exciting this track will be or if we have to change something to make it more fun.
this track will be portable then. a case for the carpet squares would be nice to carry it around.
the lane parts will be reusable in different combinations, only few will be special and usable for limited tracks.
the lane border will be sprayed with white and the rest with green paint.
we still don´t know how to make the curps and attach borders between the lanes. but well tell you when we found out s.th.
can anyone tell me whats the right sign for inch?
and how is curps spelled right?
Old 10-02-2002, 03:15 PM
gertman's Avatar
gertman gertman is offline
the sign for inches is this: "
I believe you been curb or curbs as a type of barrier.
-Engineering Manager
Old 10-02-2002, 07:13 PM
THX
Old 10-04-2002, 10:13 AM
tinyrc's Avatar
asimeman, the track looks cool, let us know how it goes!
Old 10-06-2002, 10:13 PM
Diego's Avatar
Diego Diego is offline
That track looks cool. What are those carpet plates and were you got them?
I made a modular track of 12" styrene (lights cover) plates with 10" wide lanes. I made it originaly for my Bit Char-g, but I'm using it with my 2 new Epochs. It's a little tight especially on the curbs but it's fun anyway.
I'm using 2 layers of 1/4" rope nylon for barrier. One stick on top of the oder with hot glue. I's preaty nice. Stop the cars without hurting the paint, bouncing the cars to the oder side nor making to much drag when hitting the wall.
Hope this could help you
Diego
Old 10-09-2002, 04:09 PM
Epoch´s arrived!
Hi!
Today we got our Epoch´s. Look pretty cool! We had to make a lot of pics.
Old 10-09-2002, 04:10 PM
pic2
Old 10-09-2002, 04:11 PM
pic3
Old 10-09-2002, 04:22 PM
Track tested and found to be fun!
Track building HowTo:
You need:
35 carpet squares (look pic)
2 aerosols white paint
2 aerosols green paint
HowTo:
First you make patterns for each type of lane you need (bend, straight, diagonal). One pattern ist to spray the green paint and one for white
Pic from carpet squares:
Old 10-09-2002, 04:26 PM
Pic with green paint pattern:
Old 10-09-2002, 04:27 PM
pic with white paint pattern
Old 10-09-2002, 04:45 PM
then you have one square ready. For each different lane-type you need a pair of pattern and a few special ones for start/end and boxes.
It´s a lot of work to do, but it´s worth it. Believe me!
We made our track like on the drawing except that we decided to make the lane 11.82" (30cm) instead of 9.85" (25cm).
And now ta ta ta taaaaaaa! Our Track:
My New track and a pic of my work area zydio ZipZaps Gallery 15 01-12-2005 04:17 PM
Track idea, comments wanted MoobY Tracks 3 12-07-2004 09:01 PM
Porta-Trax announces SuperCircuits Pro Track Kits lornecherry Bit Char-G / MicroSizers 18 04-02-2004 12:34 PM
Track layout idea Talon Bit Char-G Mods and Projects 0 12-31-2002 02:39 PM
Need help track materials.. NewbieBrigade Bit Char-G / MicroSizers 2 08-06-2002 03:18 PM
