08-29-2003, 10:44 AM
TinyRC fool!
Yet Another speed Mod
This mod is very easy, but requires the use of a soldering iron.
1. desolder or rip off where shown.
2. connect the two points left after the part is removed.
3. charge and watch it go!!!
the boost of speed from this mod is minor, but i havent found any downside to doing this though.
(thanks to namuna for the use of the pic!!)
I command you to: check out the site
08-29-2003, 11:49 AM
Enlighted
I've got a shen qi wei with a PCB that looks the same but I don't have the fancy text nor the black blob... should I go ahead with this mod?
08-29-2003, 12:58 PM
and what does this do take off a resistor to allow more voltage to the motor in other terms a simple semi mosfet?
08-29-2003, 06:02 PM
do u have a version for the big lots thunder charger clone
08-30-2003, 12:57 PM
TinyRC fool!
i didnt test the voltage output yet, it should be higher, and this will probably work on clones, it will do the same thing to their electronics.
09-03-2003, 04:35 PM
SUPREME RULER
would one glob of solder connecting the 2 points work. im really concidering trying this! good pic and directions
09-03-2003, 05:59 PM
TinyRC fool!
of course one glob of solder would work, you just need to connect the points.
09-16-2003, 05:43 PM
i just finished doing it put i did not connect the two points and it still worked do i have to connect the two points so it can work good??
09-16-2003, 05:51 PM
i just took it for aride ant the reception is the worst it wont even go 2 feet
09-17-2003, 04:02 PM
TinyRC fool!
that's strange, i didn't notice any range loss when i did this.
09-17-2003, 04:03 PM
i had to go exchange it for a new one in target
put of course striped it compleatly
