08-27-2003, 02:05 PM
maximun #of cells????????
any1 no wots the maximum amount of cells i can use on my bit b4 it explodes
im thinging of adding an adittional 3 (thats four in total)
o and im setting themn up in a series for maximum speed if that makes a differenc.
o and will my motor burn out with 4 cells??(tomy 2.6)???????????
08-27-2003, 02:56 PM
ok quad cells are fine any higher not fine. quad cells have been known to char somthiing on the pcb but thats rare and 2.6 probly wont burn out but putting higher voltage through it will shorten its like
08-27-2003, 04:32 PM
thx
i tried it 2 day with 3 cells on my superbit and it didnt run????????
im gunna wait till the weekend buy me a clone and 3 cell that
see if that werks
08-27-2003, 05:22 PM
Tiny RC Pro
The chips were designed to go no higher than 5 volts!
08-27-2003, 05:34 PM
Bit Obessed...
I think that you should make a switch on the car for charging, since 4 cells would be 4.8v, and 3 alkaline batteries in the charger/remote - 4.5v, wouldn't be enough, you would need 4, which would make it 6v, which inturn might fry the PCB when charging. So I think you should make a switch which disconnects the PCB from the battery when charging just to be safe....
08-29-2003, 12:29 PM
Cuttin' up Daisy
Aren't 4 cells just a wee bit heavy? Why don't you try a CR2 camera battery, they give 3V, and will give your car at least an hour of runtime.
08-29-2003, 12:51 PM
to heavy not with all that power
