Old 08-08-2002, 08:22 PM
infinite infinite is offline
Talking New Update On Booster With Hard Antenna !!! Now Up To 50ft!!!
hey everyone,
i just soldered the antenna wire to the retractable antenna and i replaced the old antenna on my car with cat5 wire from left over telephone wire that you run along the walls.
now i get like 50ft i'm thinking.. i was on the 3rd floor of my house i sent my bro to the basement so i'm thinking that's like around 50ft and the signal was still going strong.!!!!
to put the antenna, in i clipped a few pieces of plastic off. the antenna i got from a local electronics store and it cost 1$ and the wire was free
here's a pic.
Old 08-08-2002, 08:24 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Nice - 50' through solid objects too - you should try it in a wide open area, you'll probably get even more (not that you'd be able to see it that far away! ).
Old 08-09-2002, 07:53 AM
ylexot ylexot is offline
How long is the antenna? This is the next step for my booster. I tried putting a longer wire on the remote, but that was a PITA and it didn't seem to help much.
Xanavi Hiroto Skyline GT-R 57MHz
Booster 35MHz
MicroQ Porsche 45MHz
Peugot Bullet 49MHz
Skyline GT-R Bullet 40 MHz
WRC Impreza Nikko iRacer
Subaru Impreza and Toyota Bb Bodies
Old 08-09-2002, 12:02 PM
tinyrc's Avatar
Idea: has anyone replaced the crystals in the 4ch to see if you can for example make one that will let you control your 49MHz cars?
Old 08-09-2002, 03:55 PM
well the antenna when full retracted is about 1 1/2 ft maybe a little bit longer..
i haven't tried to change the crystals, but my brother said that maybe if you take off teh other crystals that the range might be alittle better. but i guess that kinda defeats the purpose of a multi channel remote.
Old 08-09-2002, 09:54 PM
dumboi07 dumboi07 is offline
Send a message via AIM to dumboi07 Send a message via Yahoo to dumboi07
secure antenna?
how did you secure your antenna in place? and did you remove your existing antenna? if so, how?
Just in case you're wondering, im not new to bits, just to the forum.
Old 08-10-2002, 02:04 AM
well i had to cut a bit of the plastic off of the remote, after that it sat quite nicely in the original hole, and the metal plate that was originally in the remote is actually holding the antenna in place. You can see it if you look closely.. it's the metal with a bit of red on it.
i just cut the original atenna off with a pair of wire cutters. and then unscrewed the wheel off the back and cut off the end.
then i secured the antenna wire to the retractable antenna with solder.
27mhz Evo 7 lancer w/ 3.0 motor + headlights
modified booster remote now with 50ft of range
45mhz oem thunder bensu blue skyline
both with new NiMH batteries 30min run times
Old 08-10-2002, 05:21 AM
Question Huh?
Huh? i dont get it... so how is the antenna stuck to the metal plate? if you pull the antenna too hard, wont it come out? or does the plastic secure it in place?
Old 08-11-2002, 01:05 AM
the hole that is originally there was just the right size for the antenna i bought and if you look closely the antenna bottom is kinda in a "L" shape. so that itself prevents the antenna from pulling out. but the metal plate that was in the remote in the first place is hold the retractable antenna down.
if you really still don't understand what i'm saying i'll take my remote apart and try to post some more pictures pointing it out to you.
Old 08-12-2002, 04:08 AM
Talking Please?
Hehe... thanks in advance, hence the name, dumboi hehe ok.
im dum ya so pleace could you do that? cause im still . thanks again
Old 08-12-2002, 03:48 PM
ok here is another picture of the inside of my remote.. the little "L" shaped metal piece on the table is the piece of metal holding down the antenna.
and the long piece of metal attached to the antenna came with the antenna.
Old 08-12-2002, 03:54 PM
Thanks!
Thanks!
Old 08-12-2002, 05:08 PM
sneuburg sneuburg is offline
Where did you get the antenna? Radio Shack? And what was the part number if you still have that info. This looks like a great mod! Thanks for sharing it!
Old 08-12-2002, 06:07 PM
nope i didn't pick up the antenna at Radioshack. i bought the antenna at a local electronics store by my house called Active Surplus. For those that live in Toronto, it's on Queen St. and it only cost me $1....
Old 08-18-2003, 03:07 PM
Nitrolio Nitrolio is offline
Send a message via AIM to Nitrolio
where exactly is the cat5 wire at? i see a stck antenna. i suck sorry
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 10:38 PM
Antenna Booster Riven Bit Char-G / MicroSizers 3 12-27-2002 05:43 PM
Booster: Buttons Hard to Push! killboy Bit Char-G / MicroSizers 0 09-21-2002 09:16 AM
booster remote with longer retractable antenna!!! infinite Bit Char-G / MicroSizers 8 08-12-2002 07:25 PM
