Old 07-16-2003, 10:11 AM
Daisycutter's Avatar
Daisycutter Daisycutter is offline
Cuttin' up Daisy
nomad, if you are gonna go with a ff glider conversion, you should use the n20, right now i'm busy with college, but when i have the time i'm gonna build me a MOTH
Old 07-17-2003, 08:34 PM
nomad nomad is offline
n20?
Old 07-18-2003, 05:54 PM
JesterDotcom JesterDotcom is offline
3D Racer
http://www.gem.hi-ho.ne.jp/no-koshob...x/projectx.htm
thats the sight the planes from if you translate it it says that he never got it to fly
Old 07-19-2003, 09:13 PM
when I tried to translate it, it didn't work right.
if he never got to fly it, it could still work.
I saw some videos of someone's plane flying that looks like the one from that site.
Old 08-07-2003, 08:03 AM
vinnyg vinnyg is offline
Send a message via AIM to vinnyg
hey guys,
i have made a free flying bit plane using 2 150mah nimh cells, a motor from a motor works car and zipzap blue gearing. on a stick plane that i made, kindof like a rubberband plane. flies level and will even climb. the next step it to make it rc with throtle control and rudder control. just hope it will fly with the extra weight of the rx.
vin
Old 08-07-2003, 08:06 AM
sorry
sorry guys i didnt know this post was so old, i thought i was on the first page when i looked at it. ill try not to do it again
Old 08-07-2003, 10:02 AM
eman1 eman1 is offline
custom title
Thats not a problem at all that you brought it back to the top. A lot of people probably didnt see this before
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Old 08-08-2003, 12:21 AM
Cuttin' up Daisy
Vinny,
the RX weighs 1.8 grams, hope that helps
Old 08-08-2003, 10:40 AM
thanks
thanks daisy cutter, i thought it weight more than that. i just have to get some light wire cus the wire that i have is too heavy. do you know where i can get some small light flexible wire?
im also trying to do a harbor freight free flight lightnening conversion with an e charger motor and 3 nimh's. i am using this rx from a clone. it is the simplest and lightest rx i have ever seen. when i measured the voltage drop from the battery to motor outputs, it was only .013 volts!
thanks again
Old 08-08-2003, 12:09 PM
hazzamaya
DUDE! I wish they could make a char-g micro helicopter!THAT WOULD BE !SWEET!
Old 08-08-2003, 10:58 PM
Actually they already have done it
heres the pic
and here is the link to the long discussion about them
http://www.rcgroups.com/forums/showt...5&pagenumber=1
Old 08-14-2003, 08:54 AM
does anyone have a clue where I can get one of those balsa rubber band planes?
I really wanna get started making my plane but I have no clue where to get one of those planes.
ever notice how you can find things without a problem until you need them?
Paper Bird 1 (home made bit plane) Comrade_Boris Micro Flight 10 10-27-2003 09:20 PM
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
Bit Plane batesjm Bit Char-G / MicroSizers 11 01-13-2003 12:26 PM
