07-16-2003, 10:11 AM
Cuttin' up Daisy
nomad, if you are gonna go with a ff glider conversion, you should use the n20, right now i'm busy with college, but when i have the time i'm gonna build me a MOTH
07-17-2003, 08:34 PM
n20?
07-19-2003, 09:13 PM
when I tried to translate it, it didn't work right.
if he never got to fly it, it could still work.
I saw some videos of someone's plane flying that looks like the one from that site.
08-07-2003, 08:03 AM
hey guys,
i have made a free flying bit plane using 2 150mah nimh cells, a motor from a motor works car and zipzap blue gearing. on a stick plane that i made, kindof like a rubberband plane. flies level and will even climb. the next step it to make it rc with throtle control and rudder control. just hope it will fly with the extra weight of the rx.
vin
08-07-2003, 08:06 AM
sorry
sorry guys i didnt know this post was so old, i thought i was on the first page when i looked at it. ill try not to do it again
08-07-2003, 10:02 AM
custom title
Thats not a problem at all that you brought it back to the top. A lot of people probably didnt see this before
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
08-08-2003, 12:21 AM
Cuttin' up Daisy
Vinny,
the RX weighs 1.8 grams, hope that helps
08-08-2003, 10:40 AM
thanks
thanks daisy cutter, i thought it weight more than that. i just have to get some light wire cus the wire that i have is too heavy. do you know where i can get some small light flexible wire?
im also trying to do a harbor freight free flight lightnening conversion with an e charger motor and 3 nimh's. i am using this rx from a clone. it is the simplest and lightest rx i have ever seen. when i measured the voltage drop from the battery to motor outputs, it was only .013 volts!
thanks again
08-08-2003, 12:09 PM
08-14-2003, 08:54 AM
does anyone have a clue where I can get one of those balsa rubber band planes?
I really wanna get started making my plane but I have no clue where to get one of those planes.
ever notice how you can find things without a problem until you need them?
