Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Science
Old 07-21-2003, 06:47 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Originally posted by rmyc
umm... ok Azimov
it's hard to belive your bits can be controlled accross a football feild... well if soo maybe you can try making a solar bit plane.. or a solar blimp with that range
Maybe so, but it is true non the less. And, I don't own Bits, just Zips. Do a search on my posts and you'll see how it is done. Or, you can just go on nonbelieving.
Old 07-30-2003, 04:38 PM
BrokenMonkey's Avatar
BrokenMonkey BrokenMonkey is offline
Send a message via AIM to BrokenMonkey Send a message via Yahoo to BrokenMonkey
wow, that is really nice. is the body styled for any reason other than to just look cool? its a great body and it makes it look like one of those real life solar race cars. how fast does it go in scale mph?
Can't think of a signature now
Old 07-30-2003, 06:18 PM
Azimov's Avatar
The body was made to fit the solar array and the Zip chassis. I did use existing solar cars as a guide though.
No idea. I never had any interest in that sort of thing. I would compare it to a dual celled Zip.
Old 08-03-2003, 03:18 PM
Lord_Nick_D's Avatar
I cant stop modding
does it work off of indoor lights aswell
Old 08-03-2003, 03:33 PM
Azimov's Avatar
No, indoor lights don't provide enough light. It will run off of 500 watt halogen work lights though. But you can only drive inside of the light pool. Full sun is the way to go. In a nice smooth parking lot or concrete driveway, the thing runs forever.
Old 08-03-2003, 05:44 PM
I cant stop modding
I wonder if you changes the wheels if it would run outdoor better and add a bit of speed
do zips run better outside then bits
Old 08-03-2003, 06:02 PM
Azimov's Avatar
You mean offroad? Not really, these micros are just to small to run on anything but smooth to semi smooth surfaces. I'm doing a larger scale offroad car next for this very reason.
Neither one. same answer as above.
Old 08-03-2003, 06:06 PM
2fast2furious59's Avatar
2fast2furious59 2fast2furious59 is offline
Independent Motorsports
Send a message via AIM to 2fast2furious59
hey do u mind showing us any pics of teh guts on these solar powered zips...this is an interestign topic and if i had the funds i would do it...but i'll have to wait till end of october when i get my job
Old 08-03-2003, 06:13 PM
Azimov's Avatar
I've pretty much shown all there is to see in the three threads on the cars. There really isn't any serious modifications in the chassis except for removing the stock battery and putting a super cap in there.
Old 08-11-2003, 11:21 AM
charliebrown's Avatar
A nice project!!! VERY NICE!!! And imagine the voltage......WOW......NOW all you gotta do is put KIT gears on the car along with a 4.2 motor and NOW you are speeding!!!
Old 11-30-2003, 10:54 PM
sawhit4 sawhit4 is offline
i have a question about solar cells. if you hooked one up to the battery terminals and didnt put a cap in it would it still work? also if you hooked a solar cell to the recharging tabs, would it recharge the battery if you left it in the sun?
Old 12-02-2003, 12:22 PM
Azimov's Avatar
Yes, and yes. The solar cell output would need to match the battery however. That is, it would need to output 1.5VDC @ 50mA. This would mean that a 1 hour charge would be needed to fully charge the battery. 1.5VDC @ 200mA output would mean 15minutes in full noon day sun. Of course, you can keep pushing these numbers until the battery is no longer needed and the car runs off the solar array alone. Adding a buffer cap in this instance is required to enable driving out of shady spots. At these higher levels, the battery needs to be removed from the car as it would quickly overcharge. This isn't a problem with caps as long as the voltage limits are not exceeded.
Old 01-19-2004, 12:54 PM
cheesehead cheesehead is offline
Cheaper cells?
I have found some better cells for this stuff. Edmund Scietifics sells some REALLY small cells (2x4 cm.) that chug out .5V@250ma (http://scientificsonline.com/product.asp?pn=3081619), so you could use 3 to make a long-running car, or 4 or even 5 to make a solar-powered rocket.. Alternately, you could use the even more amazing 2x6 cm. cells that chug out 500ma@.5 volts (http://scientificsonline.comproduct.asp?pn=3037344). The .5volt cells should work well, as they are only 6.00 ea. and 4 would work nicely with a low end motor and gearing setup.
EDIT:
The best deal is the Electronics Goldmine's "B" solar cells. At a lowly 2.50 each, they're dirt cheap, and 5 should work nicely on a ZZ.
I would use something cheaper, though, as I can't afford to blow 20$ on one of these things...so maybe one of those 8.00 cheapies would serve my nefarious purposes better.
So, here's the proposed budget for my solar car:
5 "B" cells-12.50
1 farad supercapacitor-3.50
(http://www.allelectronics.com/cgi-bi...-12&type=store)
Cheap bit clone-8.00
TOTAL: 24.00!
Old 01-20-2004, 01:06 AM
Azimov's Avatar
Nice find! I'll have to check those cells out.
Old 01-20-2004, 01:20 AM
Draconious Draconious is offline
Send a message via AIM to Draconious
http://www.siliconsolar.com
Thin Film Solar Cells, inspired by azimov Jazz32 Miscellaneous Discussion 5 07-23-2006 01:15 AM
Solar Power theone&only.... Epoch RC1/43 7 12-12-2004 11:51 PM
rtr hpi micro rs4. spy esc, 2 bodies, plus extras isk8blind For Sale/Trade 0 08-31-2003 05:38 PM
Solar Micro #2 Azimov Bit Science 22 06-07-2003 06:58 PM
Solar Zip Azimov Bit Science 21 06-03-2003 02:15 AM
