07-22-2003, 12:23 PM
Drag racer
I am going to make a super fast drag racer but I was going to put a tri cell and a wheely bar to start with if any body has any ideas it would be great if you told me.
You know ya ar a red nek if ya porch colapses and kills mor than 4 dawgs.
07-22-2003, 12:52 PM
... cut the tri cell do a quad cell
07-22-2003, 01:47 PM
Tortured Primate
ahh5hit's wheelie bar is the coolest.
great pics and instructions here.
http://tinyrc.com/forums/showthread....threadid=12318
Imagination is more important than knowledge...
Albert Einstein
07-22-2003, 02:13 PM
get some wide rims and tires for the back get teal ms gears and get aholde of a 7t pinion to increase speed pick up some 4.2's underglow 200mah cells
heres what i run my zz with
 fornt  back  with 7t pinion  i still havnt gotten my 4.2's >
07-22-2003, 02:57 PM
Thanks labmonkey! Also, you can get your wheels from this car...
07-22-2003, 03:00 PM
They have the perfect tires for the front. You may want to add the spring suspension too to soften the landing to prevent the front wheels from being damaged because they are pretty skinny. Note: the turning is horrible with these front wheels, but if you are gonna use it for drag, then you will be ok. Here is my drag car with the wheelie bar labmonkey mentioned and the same wheels.
07-22-2003, 04:46 PM
0reZepyT
how well does these hotwheel tires grip? r they even rubber?
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
07-22-2003, 05:02 PM
Yes, they are real rubber. The front tires are basically a oring wrapped around the rim. The steering is bad since there is no surface area for the tires to grip. Other than that, the rear tires do grip, but not as good as regular Zip tires.
07-22-2003, 08:08 PM
how do you install them and do you have to drill at all and how much do they cost
07-23-2003, 08:52 PM
That Hot Wheels diecast was $7.99 at Target. You basically install them as you would any other wheel mod. Just perform a search. You do have to drill thru the front wheels. You have to be extremely carefull as they are very thin.
07-25-2003, 08:21 PM
I used muscle machine tires, the grip is good on carpet, now I just need 30' of carpet...hehe
07-26-2003, 02:19 AM
I need to change my Title
r...rr....rr...r thoose zip zaaps(said stuttering)???
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Celica body
07-30-2003, 02:23 PM
woah. those r AWESOME!! did you make those or what? r u selling any? those r COOL
Can't think of a signature now
07-31-2003, 12:18 PM
where did you get those sweet bodies
how did you fit a zz chasis in there
07-31-2003, 02:11 PM
Monoaural.
J-On
