Old 07-11-2003, 11:02 PM
Bad Company's Avatar
All of you good internal modders should really consider doing some of these mods to the new NASCAR Motorworks cars. They are as fast out of the box and look like they have potential for modding.
Old 07-11-2003, 11:05 PM
Steve's Avatar
Steve Steve is offline
zipped up tight!
any reports yet on the guts of the Nascar series? Same as 2F2F or different?
Old 07-11-2003, 11:12 PM
Here is a pic I took of the internals. The pcb board is smaller than most other boards. Also, here is a link to the full thread that I covered alot of details on these cars.
http://www.tinyrc.com/forums/showthr...threadid=12227
Old 07-12-2003, 11:49 AM
vtheo's Avatar
vtheo vtheo is offline
Monoaural.
Steering wires resoldered, motor wires switched, yep those front wheels like to slip out when i boost it, sure looks cool when it flips around three or four times faster than any bit or sip i have seen. i have some time today i plan to dual cell my short (old) motorworks and replace the front wheels on the awesome rc. i want to put the huge tires from motorworks on it and make a jeep rugrunner out of it. I will keep you guys updated.
J-On
Old 07-19-2003, 02:39 AM
ricky ricky is offline
I just bought a nitrous bottle car I believe its a motor werks but Im not sure corect me if Im wrong but the range is realy really crappy like literally not even an inch ne one else have this prob If u did n u know how to fix it please help me I like the car n the way it looks /runs but It werks fine with my clone vontroller soI guess its the controller maybe a cripple cap gone bad er something
Old 07-20-2003, 12:32 AM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Well, definately sounds like a controller problem if the car works with another one. There is no crip cap, not that it would do this anyway, and the brand name is Awesome RC. Open the controller and check the antenna connection. Or, take it back if you aren't comphy doin that.
Old 07-20-2003, 01:18 AM
charliebrown's Avatar
I recently got an Awesome RC rom Walmart after wanting one for 2 months. It doesn't go as fast as you described, Az. Oh, a hard carpet makes GREAT surface for the stock A.RC. And the turbo button boosts speed by 50%. Also...get this...When I was there I saw a 1:18 scale die cast mitsubishi lancer..with the green eclipse paint job!!! Man, they must've messed up soemthing at the factory!!! Also they have nice 1:18 F&F die cast cars at toysrus.
All I can say is....these cars are nice. you posted a great subject, Az.
Old 07-21-2003, 03:11 PM
Azimov's Avatar
Here's my new rugrunner. AwesomeRC car with MW gearbox and Zip wheels. This is the most impressive performance car I own now. It flies across almost any surface. The torque is simply unreal. It can leap into the air when jumping onto rugs and can actually push objects out of it's way. Fender flares were added to blend the wheelbase with the thin body. These Awesome cars are the only ones I have that can snap the front wheels left and right while steering with the car standing still.
Old 07-21-2003, 04:04 PM
Awesome job Azimov(no pun intended)! That just might bring the one I have in the closet back to life for a project. Good work as usual!
Old 07-23-2003, 02:46 PM
red2cwm
Azimov, Which type MW car did you use? Nascar, short in square box, or newer longer chasis in square box?
Old 07-23-2003, 05:36 PM
Azimov's Avatar
I used one of the old short versions. Any of them will work, even a Zip gearbox as they are all pretty similar. You could probably use the new Nascar gearbox as well as it would allow for a more slim rear end. I used the old one so I could use Zip idler gears and axels so I can interchange them.
Old 07-23-2003, 08:33 PM
Steve's Avatar
zipped up tight!
that's lookin' like a Subaru rally sedan! I like it hhahaha! Throw some big ol' auxilery headlamps on the front bumper and it'd be perfect!
Old 07-23-2003, 09:05 PM
Azimov's Avatar
That's not a bad idea! I think I'll take that bit of advice.
Old 08-02-2003, 09:27 PM
I also just started a new string on bigger Awesome RC cars that I found at Toys R us, (Yep I'm still a baby, only 13 yrs older with NO difference!) and here are some pictures, they have more traction and the same controller, but bigger. and also it is 1/35 scale.
Old 08-02-2003, 09:28 PM
And the box (though it is torn up)
improved runtime!!! gtr2112 Bit Char-G / MicroSizers 4 12-20-2002 08:44 PM
