Old 07-04-2003, 08:36 AM
boho's Avatar
boho boho is offline
Camera springs
duall cells for drifting
I wanted to let people know about this. I recently did an internal dual-cell by taking out the piece of plastic between the battery compartment and the motor compartment. I did leave a little of the bottom part for stability. I did this so the batts would sit back farther. I got the batts to sit almost all the way back to the middle gear pin. Of course I had to restructure the motor connections a little. I'm sorry, but this is a lot of dremel work. So if you don't like dremels, or don't have one, then this might not be the mod for you.
PERFOMANCE: Outstanding. The weight gets distributed much better. I put the stock mediums back on and it handles better then any other car I have. I can drift it much easier then any thing I've seen for the bits yet. We all know drifting bits is easier said then done, but with this mod it took me about 5 minutes to get good with drifting this car. I haven't tried it on carpet yet, but I imagine you would need slicks for drifting on that. IT BARELY EVER SPINS OUT! I go from 0 to mach in a perfect straight line (with a new 3.8). I think because there's more weight in the back then the back tires stick better. It also doesn't flip easily. I have to hit a pot hole to make it flip.
DRAW BACKS: As with most dual-cells, when it gets up to speed it doesn't turn as sharply. So.......... slow down!
If you're good with a dremel, then I would deffinitely give this mod a try.
Sorry if I just posted something that's been posted before.
Old 07-04-2003, 12:51 PM
strider_mt2k
I have performed the same mod, but using only precision cutters.
It's nice because the batteries sit side by side.
I break off the tabs that touch the original battery, leaving the charging contacts and wires to the PCB. I then solder my battery wires to the PCB. where those wires meet up.
I did use a dremmel to open up the PCB cover so I could re-use it.
Here is a link to my Yahoo Photo Page showing the mod.
Once you know where to cut and prepare your dual batts for installation, the mod goes very quickly.
Old 07-04-2003, 06:09 PM
boho's Avatar
Camera springs
Nice job strider. Mine's slightly different. The batteries sit the other way. One battery's side (not + or - side) sits almost against the middle gear pin. That means I had to cut the motor connections (the metal peices that connect to the motor) down to about half the size to get them to fit in.
Do you have a pic of your precision cutters? I may want to pick up a pair, but I'm not sure about them.
Old 07-04-2003, 11:26 PM
moshbmxa's Avatar
moshbmxa moshbmxa is offline
TinyRC Car Killa
Send a message via AIM to moshbmxa Send a message via Yahoo to moshbmxa
i think what he means by precision cutters is a pair of tin snips?
Old 07-04-2003, 11:28 PM
moshbmxa's Avatar
TinyRC Car Killa
if you look in the link sent above...
http://photos.yahoo.com/bc/strider_m...tos.yahoo.com/
there is a picture of the precision cutters he used...sorry, they are no just tin snips.
Old 07-05-2003, 07:21 AM
boho's Avatar
Camera springs
Thanks mosh, I didn't see that the first time. Sorry stride, but I like my dremel too much.
Old 07-05-2003, 08:41 AM
strider_mt2k
Hehe, np, i just thought I'd shoot ya the info.
Old 07-06-2003, 10:10 PM
boho's Avatar
Camera springs
Mucho appreciato.
Old 07-13-2003, 10:44 PM
maxximum attack
Hi Boho,
Can you post some pics(maybe step-by-step) if your duel cell mod. And, as an added bonus, a vid of your drifting bit.
Drifting Proves MAXXIMUM ATTACK
Old 07-13-2003, 11:31 PM
I have a beach ball...
Hey strider, is that tape on your rear tires?
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 07-14-2003, 08:37 AM
boho's Avatar
Camera springs
I will post step by step instructions with illustrations, but not for a while. As for a vid, that may never happen. Don't have a recorder. We'll see though. One of my friends has one.
2 740mah Lipo cells and charger, $7.50 Jazz32 Miscellaneous Discussion 5 01-17-2007 11:25 PM
Thin Film Solar Cells, inspired by azimov Jazz32 Miscellaneous Discussion 5 07-23-2006 12:15 AM
Li-on AA cells Desslok XMODS Parts and Hop-Ups 30 04-13-2004 10:01 PM
Selling my skyline with 6 cells! ihatter For Sale/Trade 7 02-04-2004 01:46 PM
button cells for layman's mod TypeZer0 Bit Char-G / MicroSizers 3 06-18-2003 09:18 PM
