Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Science
Old 09-27-2002, 11:44 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
def,
if you're talking about mini z bodies, there are several online shops;
dinball
towerhobbies
hobbyetc
hobbyshoponline
minizracer
Old 09-28-2002, 07:09 PM
aballen
Has anyone tried a PCB antenna
I was thinking you could make a PCB antenna pretty easily. Using a square coiled pattern. If you use a double sided pcb you will get 2wice the length using the same amount of space.
I've seen this done for small bugs, the PCB includes the antenna and by doing this you dont need a long wire... it makes them easier to conceal.
If I have time I'll try it a post my results.
Old 09-28-2002, 08:34 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
one side of the coil tends to cancil the otheer out. Thats why you zip-zag instead of coil. BAE
Smaller models, more control
Old 10-15-2002, 03:41 PM
Montoya1 Montoya1 is offline
Caver,
When these ideas are perfected please make them cpmmercially available to those of us without the abilty?
Old 10-15-2002, 06:43 PM
I have to test my 'camo' antenna. I haven't had a chance yet wits any bit. I am too worried about getting a replacement.
I just found out that "MammothMarine" has a set of boosters for $100. That's 4 cars and a X-mitter. Of course I bought the set. I just couldn't keep quit about it knowing how we all feel. If TinyRC had the set I would have bought it here. But I can't find Boosters here. I am now torn between putting them away for potential neices and nephews. (sic) I'll get the mods from Tiny of course. I wish that I could have gotten the boosters here also.
We have been playing with the oem IRs that we got from tinyrc. They rock! I'm probably the only one around here to know which kit car they actually ended up with. Not on purpose, I'm sure. But it is a GOOD replica. BAE
Old 10-17-2002, 11:37 PM
rmyc's Avatar
rmyc rmyc is offline
Perfected Bit Modder
Unhappy
i tried making an internal antenna and gave me a worse reception
Old 10-18-2002, 05:54 PM
One side cancells out the other. BAE.
Old 10-18-2002, 07:58 PM
rmyc's Avatar
huh what do ya mean by that?? i did do zig zags
i also tried like 5 other external antennas ..will post soon
Old 10-22-2002, 01:57 AM
caver01's Avatar
caver01 caver01 is offline
Finally someone else is doing this
Ok, so great pic, but how does it work? I am glad somebody else is trying this out. If it were not for the damn cat, I would have a nice piano wire antenna, but this is interesting. Anyone else wanna post a pic of a wild antenna idea?
Old 10-22-2002, 10:14 AM
clex clex is offline
Question
i noticed that most antenna mods involve various wire configurations. has anyone tried using a section of a metal tape measure (mini, of course)? i remember reading somewhere that naval cadets at annapolis used a home depot tape measure and used it for several antenna on a school built orbiting satellite. i figured weight could be an issue depending on the length (could change the center of gravity also), but the antenna is upright and flexible. a sturdy enough connection and where the antenna exits the body is another issue to deal with. the tape measure cost is only $2+ from most anywhere. if you play your cards right, you can cut up a full size tape measure and use it for a rear spoiler. i just might buy a clone to test this on.
Old 11-16-2002, 10:07 PM
xXx_Vegito_xXx's Avatar
xXx_Vegito_xXx xXx_Vegito_xXx is offline
Thumbs down stained glass foil
that idea with the stainded glass foil doesn't work. I tried it and it reduced my range i just think it's conductive enough. i'm going to try it with the copper sheeting i don't know it might work better i guess i'll just have to find out. but i will not remove the stock antenna untill i know it works thanks for the idea c ya
Specs
custom paint
Honda s2000
3.0 motor (came as stock motor)
medium tires
Old 11-17-2002, 12:50 AM
microsizer microsizer is offline
Send a message via AIM to microsizer
Hi, i have a quick question will the wire of a telephone cord work for a antenna, sum1 told me it would work. so i opend it up i took out 1 wire out of the 4 and i cut the plastic so that the wire would show and i found a string (made out of cloth or cotton sumthing) well can i still use this wire? and will the string effect the reception?
Old 11-17-2002, 02:48 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
heh. you know those cell phone antenna boosters? well one came with a faceplate for my phone and sucked. i wonder if it would work for my rc car.
Old 11-23-2002, 02:08 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Holeshot - cool - thanks for the report!
Old 11-23-2002, 03:56 PM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
Send a message via AIM to Pojo
holy crap that's massive range....mine can go..*starts counting his steps*...about 7.5 feet before it bums out!
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 08:09 AM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 12:25 PM
Alternate Soldering Ideas??????? tory_103 Bit Char-G Mods and Projects 4 12-23-2002 09:49 AM
TallgeeseIIII's Bit Char-G Ideas & Concepts TallgeeseIIII Bit Char-G Mods and Projects 8 12-13-2002 03:32 PM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 12:13 PM
