09-28-2002, 02:47 PM
Originally posted by BaY oN AiM
i have a lowered front(springs) heightened rear(tires) 2.6 motor wit dual NiMH batts.
how long to you charge your batteries for? do you wheelie alot?
09-28-2002, 03:28 PM
sLaNteD ViSiOnS
i removed the second battery...the wheelies cause to lift the front wheels off the ground thus i cant turn...
Modified controller: 3-4 minutes
Home made Stand alone 3 cell charger: 3 minutes
Home made plug in charger 3V: 2-3 minutes
"Nobody is perfect until you fall in love with them."
- Me
OH YEAH, GO KILL A BIRD!
09-28-2002, 06:47 PM
Moderator - Modifier
Keep your wheelie bar low to solve the issue...
If your wheelie bar is low, once you wheelie, the bar will hit the ground, and bounce the car back onto its front tires quickly. This effectively solves the issue for straight line drags, BUT if you use the car on courses with many turns, or other than a standard oval and straight line, this will NOT fix your problems, because everytime you accelerate on turns and out of turns, the wheelie-ing will just send your car into the wall/barriers. The wheelie bar is really a BitDra-G mod.
FYI: ZipZaps fit 2 cells completely underneath the PCB, with only one modification (cutting out the latch area for charging port docking lock). The centered weight of the dual cells, negates the wheelie effect. There is a dual cell Bit mod that fits both cells beneath the PCB, but requires ALOT of chassis modification. The original cell is moved back and will actually sit over the rear axle well, allowing for more space for the second cell to fit (follow?). The finished product however hides the cells completely beneath the PCB with no cells exposed. Definitely advanced mod.
09-28-2002, 09:29 PM
i'm workin on the dual battery mod now...whats the best gearing ad tire combo for bcg draging?
09-28-2002, 09:33 PM
sLaNteD ViSiOnS
i would say the teal gear and the softest tires u can find....
- Me
09-28-2002, 09:34 PM
IRON MAN OF BIT RACING
ok thats easy
i believe the best gearing to use, that is if you are racing on 22 foot long track, would be 8.25:1 because although it doesnt accelerate as fast it reaches a higher top speed and to use soft tires
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
09-28-2002, 09:36 PM
sLaNteD ViSiOnS
hahhahaha...
i beat u at replyin by a split second....
lol....
that was funny......
- Me
09-28-2002, 09:39 PM
dang
DANG IT!!! hahahha oh well same reply you could have jsut siad that i thoguht of this too this would have saved me time
carbon fiber hood
qfm springs
8.25:1 gearing
01-20-2003, 10:13 PM
k i have my 3:43:1 gears,r-spec,duel(mabey tri)cells on the way mabey if i can get 4 blue leds with a on/off switch(save power)i will mount each led in a corner or close to 1 under the body for a bottom and window glow effect its gonna kick ass and if i figer out how im gonna drop my car 2
01-22-2003, 12:59 PM
a nice mod would probably be to replace the magnet with a circle of metal that way when u try to steer back in it goes slow and it doesnt get sent right of the track also i think it would work cuz the electromagnets atract metal to
01-22-2003, 04:05 PM
Poor Student
I use kit racer front plastic whees/tires on the front spindles. I believe that they came from the RPM, MPH/KPH, and, I think, the ENERGI versions of KIT racers. They reduce rolling friction and steering. The steering is just enough to make the car easy to keep on line. By the way KIT racers are 3.88 clearance at my local Target.
Fight Crime <--> Shoot Back
01-23-2003, 05:13 PM
One useful and easy mod is to use the pullback rear wheels!
They are wider and slightly smaller,for better acceleration and for 6-7 bucks you get another cool body and even front wheels if you want!
Plus some rims designs are kick ass!
just my 2 cents
01-23-2003, 08:51 PM
Heres my drag car. I did the 2-cell mod and made the chassie about 1/2" longer so wheelies aren't a problem.The best part is now I can use slot car bodies on it with a little modifying.
MUST GO FASTER!!!!!
01-23-2003, 08:54 PM
here's one with the body off
MUST GO FASTER!!!!!
01-23-2003, 11:47 PM
A 2 engine, 4wd, Quad Cell mod would kick @$$ for BitDra-G. No steering, no wheelies. Perfecto!
