Old 06-26-2003, 10:48 PM
New_B New_B is offline
Wowzers...
Send a message via AIM to New_B
Unhappy Problem With Steering Wire
Oh man, this one's got me stumped. Okay, my friend asked me to fix his MS Pro because it wasn't steering "right". So, I looked in and saw a copper wire (steering wire) ripped. Assuming it was taken from the PCB, I got my soldering iron ready and opened it up. To my surprise, both copper wires were intact. I searched the chassis and found that the wire had gotten separated in the middle. Does anyone have a clue how to fix this problem?
Nothing here...
Old 06-26-2003, 11:15 PM
I have a beach ball...
Just splice the two ends together.
Old 06-26-2003, 11:40 PM
Wowzers...
How can I splice them together? (not said sarcastically)
Nothing here...
Old 06-26-2003, 11:55 PM
dabigpig's Avatar
dabigpig dabigpig is offline
ok take both wires and remove some of the coating (lighter, sandpaper, soldering iron all work) then twist the two ends together and now heat up the wire connection you just made and feed it some solder..... tada it should work now.
*** AMC Veteran ***
-- ^-_-^
Old 06-26-2003, 11:59 PM
Once you do that, I'd start looking for how it happened in the first place.
Old 06-28-2003, 01:34 AM
Char-g Ace's Avatar
Char-g Ace Char-g Ace is offline
I need to change my Title
i screwed up and the r steering wire came unsoldered. it is bad timing because i have this "mini" convention on tuesday. My soldering gun is messed up, but i need to solder to fix it. any tips?
R u tired of your desk getting wet from a drink, and not any way to keep it dry. I can deliver a cup holder/coaster to you in under 10 seconds.Don't believe me, huh, well click
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Custimized nissan calsonicbody
Celica body
New viper body has been complete
Old 06-28-2003, 01:59 AM
teamoutburst's Avatar
teamoutburst teamoutburst is offline
TINY RC RULEZ!
mix some iron filings with araldite then you have a no heat solder
My Car:
Old 07-04-2003, 02:20 AM
boho's Avatar
boho boho is offline
Camera springs
Soldering paste makes the solder stick to where you are soldering.
Really Bad Steering Problem, unlike any steering problem before it! 'Vette Nerd ZipZaps SE 11 07-19-2006 10:05 AM
Honda Civic Antena Wire Problem!!! Xmodracer1 XMODS Parts and Hop-Ups 23 05-29-2004 04:01 PM
Steering problem Vincent Bit Char-G / MicroSizers 3 11-25-2002 12:11 AM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
